• 管理员
Anybody was able to install custom watchface on iOS for the GTR?
版主: Internal errorWatchmens
主题已锁定
cloporte
来自: unknown
联系:
帖子 cloporte »
Everything is in the title , thanks !
apache
来自: unknown
Been thanked: 2 time
联系:
帖子 apache »
Yes
cloporte
来自: unknown
联系:
帖子 cloporte »
thank you !
Cocobolo
联系:
帖子 Cocobolo »
Hello apache,
can you post the instruction for that please. I have the same issue. I don't know how to Transfer the watchfaces from iPhone / PC to the watch. I can't start anything with the youtoube-tutorial. It includes chinese language. Thank you very much in Advance.
apache
来自: unknown
联系:
帖子 apache »
1. Download the custom dial(bin file) and save it in your phone.
2. Go to Amazfit app to synchronize one of an official dial.
3. In your phone, open "Files" and browse "On My iPhone > Amazfit > watchSkin”
4. Find and open the folder (official dial you just synced), there is a bin file inside and an image of the dial.
5. Copy the filename of the bin, delete the bin file, then copy/move your downloaded custom dial into the folder and rename it to the name that you just copied just now.
6. Go to Amazfit app, re-sync again the official dial that you've chosen in Step 2.
Peitacas
帖子 Peitacas »
Thanks, it worked!
just one question, can we change the pic to the new watchface on the Amazfit App? just asking because I have installed 2 news watch faces, but on the list it kept the old ones (original ones)
thanks
Peitacas
ATA1968
联系:
帖子 ATA1968 »
Can we change the watch faces that the GTR have of fabric? The black one and the digital one?
cloporte
来自: unknown
联系:
帖子 cloporte »
ATA1968 写了: 27 8月 2019, 12:36
I changed the digital one not sure how i did and i'm not able to change anymore
just a new one will always be the 3rd one .
amaztools beta works great right now .
Davidi
帖子 Davidi »
Hi I have been trying for hours and all I get is couldn’t sync!try again. Then the watchface goes back to defAult. The .bin f8le I delete is many hundreds of kB the one I copy is always only 2kb it’s as if it’s not actually downloaded . Please can anybody advise me on what is happening or what I am doing wrong ?
Steleios
联系:
帖子 Steleios »
Davidi 写了: 31 8月 2019, 13:24
I have the exact same issue! Davidi, did you find a solution?
Thank you
ermanitu
联系:
帖子 ermanitu »
I installed a stock watch face and there is no Amazfit folder in "On my iPhone" folder. It's possible that Xiaomi has changed this?
In other hand, I'm trying to install watch faces from AmazTools App, and a few of them install (very very slowly compared with official stock watch faces) and appear in the watch after that, but most of them install correctly in appareance but, after installation, default watch face appears and no custom watch face are found in the watch.
Any suggestion?
ermanitu
联系:
帖子 ermanitu »
Well, Amazfit app for iOS was updated today to version 3.4.7 and all watchfaces go ok.
hlkok
来自: Kuala Lumpur
联系:
帖子 hlkok »
apache 写了: 22 8月 2019, 14:37
I'm not sure what i did wrongly on my iOS. I have use the Amazfit app to sync one of the official watchface. But when i use the 'File' to browse 'On My iPhone'', i coud not see the Amazfit folder at all. Can anyone advise?
HL Kok
jeffrey38
来自: auh
Has thanked: 10 time
Been thanked: 12 time
联系:
帖子 jeffrey38 »
Hi Lordalpine, if you have time can you make a youtube video how to use SashaCX75 GUI, im still not able to use it :)
主题已锁定
回到 “Closed topics”
在线用户
正浏览此版面之用户: Google Adsense [Bot] 和 15 访客
