Anybody was able to install custom watchface on iOS for the GTR?
cloporte
Post by cloporte »
Everything is in the title , thanks !
apache
Post by apache »
Yes
cloporte
Post by cloporte »
thank you !
Cocobolo
Post by Cocobolo »
Hello apache,
can you post the instruction for that please. I have the same issue. I don't know how to Transfer the watchfaces from iPhone / PC to the watch. I can't start anything with the youtoube-tutorial. It includes chinese language. Thank you very much in Advance.
apache
Post by apache »
1. Download the custom dial(bin file) and save it in your phone.
2. Go to Amazfit app to synchronize one of an official dial.
3. In your phone, open "Files" and browse "On My iPhone > Amazfit > watchSkin”
4. Find and open the folder (official dial you just synced), there is a bin file inside and an image of the dial.
5. Copy the filename of the bin, delete the bin file, then copy/move your downloaded custom dial into the folder and rename it to the name that you just copied just now.
6. Go to Amazfit app, re-sync again the official dial that you've chosen in Step 2.
Peitacas
Post by Peitacas »
Thanks, it worked!
just one question, can we change the pic to the new watchface on the Amazfit App? just asking because I have installed 2 news watch faces, but on the list it kept the old ones (original ones)
thanks
Peitacas
ATA1968
Post by ATA1968 »
Can we change the watch faces that the GTR have of fabric? The black one and the digital one?
cloporte
Post by cloporte »
ATA1968 wrote: 27 Aug 2019, 12:36
I changed the digital one not sure how i did and i'm not able to change anymore
just a new one will always be the 3rd one .
amaztools beta works great right now .
Davidi
Post by Davidi »
Hi I have been trying for hours and all I get is couldn’t sync!try again. Then the watchface goes back to defAult. The .bin f8le I delete is many hundreds of kB the one I copy is always only 2kb it’s as if it’s not actually downloaded . Please can anybody advise me on what is happening or what I am doing wrong ?
Steleios
Post by Steleios »
Davidi wrote: 31 Aug 2019, 13:24
I have the exact same issue! Davidi, did you find a solution?
Thank you
ermanitu
Post by ermanitu »
I installed a stock watch face and there is no Amazfit folder in "On my iPhone" folder. It's possible that Xiaomi has changed this?
In other hand, I'm trying to install watch faces from AmazTools App, and a few of them install (very very slowly compared with official stock watch faces) and appear in the watch after that, but most of them install correctly in appareance but, after installation, default watch face appears and no custom watch face are found in the watch.
Any suggestion?
ermanitu
Post by ermanitu »
Well, Amazfit app for iOS was updated today to version 3.4.7 and all watchfaces go ok.
hlkok
Post by hlkok »
apache wrote: 22 Aug 2019, 14:37
I'm not sure what i did wrongly on my iOS. I have use the Amazfit app to sync one of the official watchface. But when i use the 'File' to browse 'On My iPhone'', i coud not see the Amazfit folder at all. Can anyone advise?
HL Kok
jeffrey38
Has thanked: 10 times
Been thanked: 12 times
Post by jeffrey38 »
Hi Lordalpine, if you have time can you make a youtube video how to use SashaCX75 GUI, im still not able to use it :)
