Amazfit watchfaces Tool
Bloccato
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Messaggio da osmat »
We have been working for a long time and continue to make our own Tool for watch faces.
Everything is built on these sources.
Support watch faces for devices
Amazfit Bip
Xiaomi Mi Band 4
Amazfit GTR
Amazfit Verge Lite
What our tool can do.
- unpacking watch faces for devices from the list of supported
- packaging watch faces for devices from the list of supported
- image preview generation GIF and PNG
Instructions for use.
- download and unzip the archive to any convenient folder on your PC
- To unpack, put the watch face file in the tool folder.
For convenient work, we recommend changing the file name
in the name of your device.
Example: Bip, Band, GTR, Verge
- to unpack, run the Unpack (GTR) .cmd file (your device is in brackets)
- a folder with the contents of the watch faces will appear in the root of the folder.
- for packaging, run the Pack (GTR) .cmd file (your device is in brackets)
You can also use the old method for unpacking by dragging to WatchFace.exe but this method is not stable.
The tool may contain bugs.
We will be glad if you help us fix them.
Thank you for helping
Made with :heart: amazfitwatchfaces.com team
Source code
https://github.com/Exomode/amazfitutils
Dear users, we temporarily stop supporting the Amazfit Watch Faces Tool. You can find the current version in the first message. Link to the source there. A more stable tool for creating watch faces you can find in this topic
viewtopic.php?f=29&t=816&p=2313#p2313
Amazfit verge lite / gtr supported
All thanks to the original author: afwafwafw
If you are a developer or you have ideas on how to help the community, be sure to contact us.
We will be happy to work with everyone.
Allegati
AmazTool_All_0.1.0.13.7z
(671.26 KiB) Scaricato 13608 volte
AmazTool All 0.1.0.12.7z
(670.29 KiB) Scaricato 5556 volte
AmazTool All 0.1.0.11.zip
(866.8 KiB) Scaricato 4365 volte
AmazTool All 0.1.0.10.7z
(668.75 KiB) Scaricato 2566 volte
AmazTool_All_0.1.0.9.7z
(667.49 KiB) Scaricato 3915 volte
Rodge
Messaggio da Rodge »
Excuse me, which cmd file should verge lite run inside?
Has thanked: 1182 times
Been thanked: 281 times
Messaggio da GIK-Team »
Rodge ha scritto: 06 ago 2019, 05:44
Unpack (Verge).cmd - to unpack
Pack (Verge).cmd - to pack
osmat
Admin
osmat
Admin
A new version 0.1.0.10
Minor compatibility bugs fixed
Fixed the problem with the arrows in the analog clock
Fixed image conversion
afwafwafw
Been thanked: 14 times
Messaggio da afwafwafw »
Great job.
BTW, what is the license of source?
I've made a python version from your source but I cannot find any license information.
Thanks.
Ferodo
Messaggio da Ferodo »
Hi there,
First of all, thanks for the tools. I have been waiting since i received my Verge Lite. Really appreciate you guys.
I am having a problem after pack back my customize watchface. The preview png and gif is solid and working. When I installed it to my watch, the face became black with only leave the ring for step. Need help, please :cry: :cry:
Allegati
osmat
Admin
Hello! You can archive the project. And the photo of what it looks like?
difranca
Messaggio da difranca »
Hi!
To test the tool, I downloaded an existing Mi Band 4 bin (https://amazfitwatchfaces.com/mi-band-4/view/3033) and unpacked it. Then I packed it again without any modification. Unfortunately, some elements did not appear on the screen despite working perfectly in the preview.
osmat
Admin
Hello! What are the elements? Give us more information send a photo or describe what is not shown. We do not have all the devices and we will not be able to test and fix .
difranca
osmat ha scritto: 07 ago 2019, 17:29
I unpacked and repacked two watchfaces.
With this bin (https://amazfitwatchfaces.com/mi-band-4/view/3033) the animation does not appear on screen and the battery indicator is only broken in preview.
With this bin (https://amazfitwatchfaces.com/mi-band-4/view/3034) only the animation and battery indicator appear on screen, but all elements appear in preview.
Ferodo
osmat ha scritto: 07 ago 2019, 06:35
Thanks for ur concern. This is what happened. I will share bin file too
L’allegato IMG_20190808_111050.jpg non è più disponibile
Allegati
Success Ori 1.bin
(836.9 KiB) Scaricato 1788 volte
osmat
Admin
Please check this file.
Verge_packed.bin
(836.9 KiB) Scaricato 1842 volte
Ferodo
osmat ha scritto: 08 ago 2019, 09:49
Verge_packed.bin
Same thing happened. I think something error from json command? Anyway thanks for your help :D :D :D
fcaronte
Messaggio da fcaronte »
But working watchface on site were come from? Are not made with this tool?
Ferodo
fcaronte ha scritto: 08 ago 2019, 18:47
Working watchface was coming from original this side. Originally it is additional from Amazfit Verge Lite through Mi Fit app. I'm only adding a "AMPM" function, adding delimitizer and customize the location. Already checked through json editor but there is no error. I found we can directly insert command for "circle" function instead of create png file. I have been working to customize watchface Bip before and nothing problem. Possibility for the watch to have a limit for overall function? If this success, I want to try to add battery and pulse function.
osmat
Admin
We figured out the file structure. But there is a global problem - these are pictures and their colors. Now we are working on it.
Ferodo
osmat ha scritto: 09 ago 2019, 09:09
Nice. Thanks you so much for your effort :D :D :D :D
osmat
Admin
New Version Available
Managed to fix json entry order
-I switch in cmd is disabled for now
watch face GTR and Verge are by default read with an inverted pixel map, are recorded the same way with inversion.
It is necessary to test it and see how it behaves to watch.
Yasp0
Messaggio da Yasp0 »
At step 5 the manual says: Copy the name of the bin, delete it, then decompress our custom dial and rename it to the original name.
The downloaded file is a bin file, I decompressed it with the tool. Then I got a map with a lot of files (png, json, log, bin). Where do I put those files? Or what to do with those files?
Maybe you should make a video of the manual?
fcaronte
I think to have useful info for you, I try to do an RGB+Black and White stripe background and the result are this
On real views tools replace red with blu and lost green and blue stripe, black and white are ok so I think black and white watch will be good.
Ps I can't post photo to can explain Better
Ultima modifica di fcaronte il 12 ago 2019, 21:17, modificato 1 volta in totale.
paraflu
Messaggio da paraflu »
Which license has the code?
imbaalu
Messaggio da imbaalu »
Hai,
I'm new here. How to create a watch face with own image for amaze fitbip?? can anyone plese suggest me the step by step guide?? thanks in advance
osmat
Admin
We share the source with you, please share your best practices with us))))
cloporte
Messaggio da cloporte »
How do you reupload the file to the GTR ?
I hav an iPhone :/
Bloccato
Torna a “Closed topics”
