Bip to Bip s watchface Convertion
Stevenest
Post by Stevenest »
hi... this watchface is for bip.. can anyone convert this for bip s? Thanks for the help.
341df4fa70aae1b3c78b974ebfc5f8cb-551965-cd0fae63e3.bin
This
(17.73 KiB) Downloaded 68 times
Been thanked: 2120 times
Stevenest wrote: 11 Jul 2025, 10:32
Please understand before doing anything
- I don't have BipS, so I can't do any testing. All testing is done through the editor only. All information about the modifications I used to perform can be found here
viewtopic.php?p=13275#p13275
- I will not modify this watch face in any case
- If you want to modify it, please do it yourself
- If there is a complaint about the infringement of rights on the watch face, the Admin can delete it immediately.
📦💾 Download
341_Bip2.bin
(17.73 KiB) Downloaded 60 times
Stevenest
Post by Stevenest »
Thanks 👍🏻.. but the battery level isn't showing? can you fix that?
As mentioned, I can't make any changes because I don't have BipS.
Everything I do is through the editor and it works fine on it.
So I can't make any changes for you.
However, there is another way to handle the json from the editor: download the json again after checking and pack it again. I noticed that the .bin is not the same size as the first method, but anyway, I can't test it because I don't have BipS. But as far as I checked in the editor, it works properly. If it still doesn't work properly, I can't help you more.
📦💾 Download
341_Bip2_packed.bin
(17.74 KiB) Downloaded 64 times
