About Bip 6
Moderatori: asoo, Watchmens
Been thanked: 2120 times
About Bip 6
Messaggio da asoo »
Since I'm going to switch to Bip6 in a few days,
I started making a watchface that will work with my Bip6. However, the web hasn't opened a space for Bip6 yet, so I'm posting it here first, so that Bip6 owners can try it out first. I hope it works properly.
In 4 days when I get my Bip6, I'll test it on a real device. Next.
Immagine.Immagine.Immagine.Immagine
Now bip6 upload area is opened ( so change link to upload area )
https://amazfitwatchfaces.com/bip/view/43804
Has thanked: 1161 times
Been thanked: 278 times
Messaggio da GIK-Team »
asoo ha scritto: 05 apr 2025, 08:21
We’ll add the Bip 6 section to the website within the next day or two, so you’ll soon be able to upload and share your watch face directly. ;)
@asoo, done ;)
Messaggio da asoo »
GIK-Team ha scritto: 05 apr 2025, 22:04
@asoo, done ;)
@GIK-Team
Thank you so much
now change link to upload area
test Uploaded already but it seems that the system did not create the QR Code section.
Thank you very much with respect.
asoo ha scritto: 06 apr 2025, 01:05
Just added the QR code functionality. We were in a hurry, so initially overlooked it. Please check if everything now works as expected. Thanks!
Messaggio da asoo »
GIK-Team ha scritto: 06 apr 2025, 08:23
Thank you very much, I will do the testing as soon as I receive the Bip 6
q1x9
Messaggio da q1x9 »
I think it doesn't really work with Bip 6.
q1x9 ha scritto: 06 apr 2025, 10:17
Could you please clarify which method or app you used to install it?
q1x9
Messaggio da q1x9 »
GIK-Team ha scritto: 06 apr 2025, 10:47
i use the qr code "developer mode"
q1x9 ha scritto: 06 apr 2025, 10:51
Did you use the QR code from our website or from the app?
q1x9
Messaggio da q1x9 »
i use the qr code from website https://amazfitwatchfaces.com/bip/view/43804 - (download -> qr code icon). i tested it four times. i didn't see an error message, if there is one.
i have the newest firmware on bip 6
Ultima modifica di q1x9 il 06 apr 2025, 11:02, modificato 1 volta in totale.
Messaggio da asoo »
asoo ha scritto: 06 apr 2025, 11:58
I'm checking the image.
Please wait...
asoo ha scritto: 06 apr 2025, 12:10
It was my mistake in managing the image
Casio has fixed it now, can try to install again.
I am working on fixing the others
I have fixed all my bip 6 watchface .
@q1x9, does everything work correctly now?
q1x9
Messaggio da q1x9 »
GIK-Team ha scritto: 06 apr 2025, 14:39
yes everything works perfectly now. thanks
conan777
Messaggio da conan777 »
Hello, I have seen that there is a beta version of Watch_Face_editor_ (Zepos) _v13.2 Does anyone have it? thank you
Messaggio da asoo »
conan777 ha scritto: 08 apr 2025, 22:35
As far as I know, the Beta version is not yet available for download to the public because it is in the testing phase. Therefore, only testers have the ability to test the program, to find bugs, or test new functions that the creator (Sasha) has added. And if found issue will be notify to developers
The release of the download to the public is at the sole discretion and authority of the developer. I will not take any action in this regard.
You can follow the progress of the program from the editor's main thread at the link below.
conan777
Ok, thank
Emiliog0
Messaggio da Emiliog0 »
I have also switched to a new bip 6 and along with the watchfaces you asoo are providing I am amazed by it and couldn't be happier.
I would love to see a pipboy animated and a nixxie tube watchface for this watch in the near future if you could consider it as possible
Thanks and keep up the amazing work
Messaggio da asoo »
Emiliog0 ha scritto: 09 apr 2025, 22:15
If I remember correctly, pipboy has the copyright, and the owner has already requested to remove his work once, including my watch face that I used to make. So, for me, I think that out of respect for the owner's rights, if it's not necessary, I won't do it.
However, this is just my personal opinion.
For the nixie style, I have made it. You can download it from the link.
https://amazfitwatchfaces.com/bip/view/43831
Next time, if you want to request a new watchface that is not related to this topic, please open a new topic.
Emiliog0
Understood!
Thank you very much!
Emiliog0
While attempting to install the watch face by the QR code, it gives a mini package error?
I also tried numerous times just in case
Messaggio da asoo »
Emiliog0 ha scritto: 10 apr 2025, 13:50
I'm not sure you're talking about which watchface
If it's my watch face, every watch face I've tested installing via QR code
and I haven't had any problems installing it.
Emiliog0
I meant the nixxie tube, but It worked now. Must have been something else then.
Thank you!
