Sentinel GR+ for GTR 3
Pox87
Has thanked: 28 times
Post by Pox87 »
Hello guys,
Hope you are good!!
if someone have time, can you kindly convert this watchface from MikeOB to GTR 3, adding maybe few color switch (e.g. sepia, lime, maroon or the one you like more )?
https://www.facer.io/watchface/5yvjkKQy ... atch4black
Thanks a lot in advance :D
romstemp
Has thanked: 10 times
Been thanked: 41 times
Post by romstemp »
Pox87 wrote: 06 Mar 2025, 06:38
Hello guys,
Hope you are good!!
I didn't do the color part that you mentioned because I don't have a sample and I don't know which part you want to change the color ( Because you did not specify) , so I just ported it as per the original that I see. If you want to make any further changes in the color part, please do it yourself. Or if anyone is interested in making additional corrections, they can do so as desired.
I will not continue with this project.
Good luck and have fun fixing some yourself.
SENTINEL_GR+_GTR_3.zip
(262.65 KiB) Downloaded 77 times
Pox87
Post by Pox87 »
Hi @romstemp sorry, you are right, i was not clear and didn't specify color switch on predefined orange zones.
Thanks anyway as the port works perfectly. Much appreciated !!
