Timezone, compass, altitude displayed on the watchface
Discussions that are not suitable for other topics.
AdrianMack
Post by AdrianMack »
Hi everybody,
I am new on this forum and I own a GTR 4.
I would to ask if it is possible to add one or more timezones on a watchface that I make with the tool https://watchface.zepp.com/
The timezones are available as widget/app but it seems not possible to add one or more on a watchface.
The compass and the altitude can be another interesting things to add to a watchface; instead of a small analogue watch I would add the compass and the altitude.
Edit:
I have found this: https://amazfitwatchfaces.com/gtr/view/39761 editable...by tapping one of the fields then a compass appears ... very nice and very well done...probably he used another tool or modified manually the javascript code.
Thankx
Guydu91
Has thanked: 55 times
Post by Guydu91 »
Hi Adrian,
I create watch faces with the SashCX75 editor that you can find here:
viewtopic.php?t=2743&start=750
Here is an example for GTS4 (square equivalent of the GTR4...) and I think it has all the shortcuts you want:
https://amazfitwatchfaces.com/gts/view/12118
I'm not sure if there is a function for altitude...
Best regards.
Guy.
AdrianMack
Hi Guydu,
thank you...the editor seems powerful but also terrible...I never know what will happen if I choose/select an option.
Some parts are like the web Zepp editor but the rest is just a guess.
I will try to do something.
Is there any manual or some documentation ?
But, aside from the editor, I would like to add the elements on the watchface, I mean not as shortcut/event when I click a button.
For example the compass should be always visible or as editable element (the so called "complication") together with the analogue watch.
So when I clik on the watch it becomes compass and when I click the compass it becomes watch again.
Thanx again
Return to “Other topics”
