• Administrador
Pesscara Convertion to GTR 3
Moderadores: asoo, Watchmens
Reglas del Foro
Responder
Pox87
Has thanked: 27 times
Contactar:
Mensaje por Pox87 »
Hello guys,
Will someone be so kind to convert Pesscara watchface ported by Lattenknaller to GTR 3 version also?
https://amazfitwatchfaces.com/gtr/view/39281
thanks in advance
KR
Avatar de Usuario
romstemp
Has thanked: 9 times
Been thanked: 41 times
Mensaje por romstemp »
Pox87 escribió: 06 Dic 2024, 11:33
Hello guys,
thanks in advance
KR
This watch face, the creator has made a simple script that can be converted to GTR3 using sasha's editor. After conversion, the script needs to be modified a little bit in the x, y values ​​to make it compatible with GTR3. I think if anyone is interested, this watch face is a good example to help you understand how to convert the watch face yourself. If you are interested, I recommend you to try it yourself.
I am not sure if the creator allows the work to be converted to other devices. If the creator does not allow it, please ask the administrator to delete this post.
This is the watch face that I have converted and modified the script in the X, Y part only.
All scripts are still Lattenknaller's.
GTR3
Imagen
Pesscara_GTR_3.zip
(752.87 KiB) Descargado 128 veces
Pox87
Contactar:
Mensaje por Pox87 »
@romstemp Amazing port! Thank you so much!!
Responder
¿Quién está conectado?
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 7 invitados
