Pesscara Convertion to GTR 3
Pox87
Has thanked: 24 times
Post by Pox87 »
Hello guys,
Will someone be so kind to convert Pesscara watchface ported by Lattenknaller to GTR 3 version also?
https://amazfitwatchfaces.com/gtr/view/39281
thanks in advance
KR
romstemp
Has thanked: 9 times
Been thanked: 41 times
Post by romstemp »
Pox87 wrote: 06 Dec 2024, 11:33
Hello guys,
thanks in advance
KR
This watch face, the creator has made a simple script that can be converted to GTR3 using sasha's editor. After conversion, the script needs to be modified a little bit in the x, y values ​​to make it compatible with GTR3. I think if anyone is interested, this watch face is a good example to help you understand how to convert the watch face yourself. If you are interested, I recommend you to try it yourself.
I am not sure if the creator allows the work to be converted to other devices. If the creator does not allow it, please ask the administrator to delete this post.
This is the watch face that I have converted and modified the script in the X, Y part only.
All scripts are still Lattenknaller's.
GTR3
Pesscara_GTR_3.zip
(752.87 KiB) Downloaded 120 times
Pox87
Post by Pox87 »
@romstemp Amazing port! Thank you so much!!
