Mi Band 4 faces Not appearing in Mi fit's local displays.
Stupidiputs
- Has thanked: 1 time
Yesterday I downloaded nearly 20 mi band faces and only 4 worked for me. The other ones doesnt appear in local faces in mi fit app. Im android user. Anyone has any info about it, maybe is it incompability with global version? Noone of the animated faces works for example.
Stupidiputs
Ive copied all faces and png this way: (i cant post a video link faak xdd, search in youtube "cara install custom watch face mi band 4" its in hindi I thinl but its the only video Ive found)
In summary, I created new folder for each band face in the "watch_skin_local" and copied in there the face and png/gif file.
- osmat
- Admin
- Has thanked: 35 times
- Been thanked: 73 times
Animated can not be installed from the local folder. Try to do a substitutionStupidiputs wrote: 04 Jul 2019, 10:27Ive copied all faces and png this way: (i cant post a video link faak xdd, search in youtube "cara install custom watch face mi band 4" its in hindi I thinl but its the only video Ive found)
Stupidiputs
Finally It works by making a substitution, but its a headache xdd
Kpochmx
Thank you, we are waiting for Quality watchfaces with really good animations.
viewtopic.php?f=14&t=709
If you are unable to use Hex program, you can try this program to patch bytes 17 to 24 in one click
Small program for patch file.bin on bytes 17 to 24 edit FF FF FF FF FF FF FF FF to 24 00 d0 03 00 00 3d 78 ( for PC )
