Question about JSON FILE
Bloccato
SrPhilippe
Messaggio da SrPhilippe »
What do these parameters (BottomRightX, bottomRightY and alignment) do?
Codice: Seleziona tutto
"Pulse": {
      "Number": {
        "TopLeftX": 47,
        "TopLeftY": 33,
        "BottomRightX": 69,
        "BottomRightY": 49,
        "Alignment": "TopCenter",
        "Spacing": 1,
        "ImageIndex": 81,
        "ImagesCount": 10
      "DelimiterImageIndex": 91
I'm not understanding it, because the code already has the TopLeftX and TopLeftY to positioning the object, right?
yzx_28
Messaggio da yzx_28 »
yes you are right
They are of no use
lvpokka
Has thanked: 19 times
Been thanked: 152 times
Messaggio da lvpokka »
No, it's showing end of place holder of image for some purpose, alignment work like where to shift text in placeholder if it's very wide
yzx_28
lvpokka ha scritto: 14 lug 2019, 08:58
However, if you enter the wrong parameters, it will not affect the image display.
yzx_28
I was wrong. I saw that one of the parameters was the alignment. If it was on the top left it didn't matter, but if it was centered it did
Translated by youdao
Bloccato
Torna a “Closed topics”
