- Administrador
How install custom watchfaces to Balance
Regras do fórum
- Registrado em: 14 Mai 2022, 05:41
- Has thanked: 205 times
- Been thanked: 5 times
- Contato:
Hello to all. Please can someone help me how i can install custom watchfaces on balance. Thank you.
- GIK-Team
- root
- Registrado em: 22 Mar 2018, 10:00
- Has thanked: 1161 times
- Been thanked: 278 times
- Contato:
Have you tried using our app, which allows installation via QR code? It should simplify the process for you on the Balance. Let us know if you need further guidance!amazfitfacesafrica escreveu: 09 Nov 2024, 09:25Hello to all. Please can someone help me how i can install custom watchfaces on balance. Thank you.
- Contato:
Thank you for reply. Finally i found way with installation via QR code. Is there way solution to install watchface with file and not with qr code because i must have another screen to scan qr code. Thank you. And i found that city name not display in my watch why?
- Contato:
Why city display in some watchfaces not showing in my watch?
- GIK-Team
- root
- Contato:
The QR code should actually appear on your watch screen, and then you scan it with your phone using the Zepp app in developer mode. This way, you don’t need an extra screen!amazfitfacesafrica escreveu: 09 Nov 2024, 09:45Thank you for reply. Finally i found way with installation via QR code. Is there way solution to install watchface with file and not with qr code because i must have another screen to scan qr code. Thank you. And i found that city name not display in my watch why?
- Contato:
Thank you GIK-Team for reply, i find the way you say.
- Registrado em: 12 Abr 2018, 16:29
- Has thanked: 130 times
- Been thanked: 19 times
- Contato:
On my T-Rex 2, I am on Android. I download the .zip file from the site with the mobile browser then use the "Notify for Amazfit" to install by browsing to the downloads folder.amazfitfacesafrica escreveu: 09 Nov 2024, 09:25Hello to all. Please can someone help me how i can install custom watchfaces on balance. Thank you.
I used to be able to install by sharing the file to the Amazfitwatchfaces app but that no longer works.
al0o0z
- Registrado em: 20 Nov 2025, 00:23
- Has thanked: 9 times
- Contato:
Can you please tell me how do you install zip file watch faces using the Notify for amazfit app?taw_bip escreveu: 14 Nov 2024, 12:46On my T-Rex 2, I am on Android. I download the .zip file from the site with the mobile browser then use the "Notify for Amazfit" to install by browsing to the downloads folder.amazfitfacesafrica escreveu: 09 Nov 2024, 09:25Hello to all. Please can someone help me how i can install custom watchfaces on balance. Thank you.
- Contato:
I install watchfaces from my Android phone this way:al0o0z escreveu: 22 Nov 2025, 01:45Can you please tell me how do you install zip file watch faces using the Notify for amazfit app?taw_bip escreveu: 14 Nov 2024, 12:46On my T-Rex 2, I am on Android. I download the .zip file from the site with the mobile browser then use the "Notify for Amazfit" to install by browsing to the downloads folder.amazfitfacesafrica escreveu: 09 Nov 2024, 09:25Hello to all. Please can someone help me how i can install custom watchfaces on balance. Thank you.
1. download the file usually in .zip format (you can also install it across a network if the file is on a NAS)
2. clear the data/cache from the Zepp app
3. load the Notify for Amazfit app (you need to set it up, get your watch's pairing code, etc. follow the instructions)
4. when all set up, click on the "Devices" icon at the bottom. Tap "Watchfaces" press the "hamburger" settings icon on the top-left. Select "Custom watch-face (.bin)"
5. This will open up the phone file manager. If the file is in your Downloads folder, select that. Then select the .zip file. Hit the "Install" button.
6. If all goes right, it will install the watchface.
7. Once you're done testing, do the storage app/cache wipe of the Notify for Amazfit app.
8. Open the Zepp app and re-login to connect it to the watch.
Quem está online
