Amazfit Tools Mi Band 4
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
Tool Description
1. The tool is based on a modified version of AmazfitBipTools-1.0.3.1, thanks to the original open source .
3. Mi band 4 supports more colors.
The official decompression depth is 32, but for 8 only, the color index is 257.
This is a beta version, the feature is not comprehensive, but this version works.
Tutorial
1. Unzip AmazfitBipTools_Mi4.zip and get a bunch of files.
2. Copy the bin file of the official dial in the phone, or use the bin file uploaded by others.
(Note here, the tool may not be compatible with bin files of other watch faces, it is best to use the official A-Trip as the base bin file )
3. Drag the copied bin file to WatchFace.exe in step 1. , get the decompressed file
1 - is to modify the corresponding image file and replace it with what we want.
2 - is to modify the corresponding json file and modify the position of the image.
AmazfitBipTools_Mi4_0.0.2.zip
(763.75 KiB) Downloaded 12603 times
AmazfitBipTools_Mi4_1.0.3.zip
(767.24 KiB) Downloaded 31798 times
Sources: https://bit.ly/2RGOZnL https://bit.ly/2XKBj0i
lukbe
Been thanked: 8 times
Post by lukbe »
do you have idea how to pack my theme for mi band 4. I used your tool version 0.0.2 - after loading of the theme in to the Mi band here is not information about steps, distance, weather.
Today i tested your last version (1.0.3), however her is not possible pack my theme. Please can you try it and check my Json file.
Thank you
00_v0_czech_30062019_packed-3080-c6d218f929.zip
(219.87 KiB) Downloaded 1892 times
osmat
Admin
Post by osmat »
lukbe wrote: 01 Jul 2019, 17:39
Thank you
Hello. Tool always creates a log file. It has the number of straki with an error.
Keep the file ready
00_v0_czech_30062019_packed-3080-c6d218f929.7z
(167.49 KiB) Downloaded 946 times
lukbe
Post by lukbe »
thank you for support.
here was problem with the line in Pulse - "Number": { and in "StepsProgress": { ?
Why is not the pulse displayed in the gif ?
what do you mean with: number of straki ? Please, can you explain how to find error? when i open my log file, here is not error message!
thank you
osmat
Admin
Post by osmat »
Tools is not perfect yet and poorly generates gif files
lukbe
Post by lukbe »
Did you something with pictures in your upload ? Because if I compare my pictures and pictures in your upload here is different quality.
I loaded your upload of my skin in to the Mi band and here is not week day and weather.
Do you have idea where is problem?
Thank you very much.
osmat
Admin
Post by osmat »
lukbe wrote: 02 Jul 2019, 16:43
This tool was originally created for bleep. There are restrictions on the number of colors. Because of this, the pictures are clamped
lukbe
Post by lukbe »
And do you have idea why weather does not work?
njman69
Post by njman69 »
The animation is so cool. Could you pls show me how to make an animation like this pikachu one ? I try and can't do it.
Stupidiputs
Post by Stupidiputs »
njman69 wrote: 04 Jul 2019, 02:37
does pikachu face work for you? It doesnt show in local faces for me, and yesterday I downloaded nearly 20 mi band faces and only 4 worked for me. The other ones doesnt appear in local faces in mi fit app. Im android user.
iparos
Post by iparos »
I have create my own Mi Band 4 wathcface but I got some problem showing correctly interface elements.
If I leave in json file only time and date directive time ad date are correctly showed but if I add Activity directive the date instead of showing day and month number show day name (LUN-MAR-etc) in day number and in day month.
Also I show Pulse and Steps using small fonts but Pulse or Steps are show with a larger font when convert json to bin.
I try many times to fix this watchface but I cant able to do so can anyone help me?
I enclose my Moto Guzzi watchface source.
P.S. is there a technical manual about json file directive and how to use and set it?
P.P.S. Is there a way to download the source of AmazFitBipTools_Mi4 so I can try to compile under OS X?
moto_guzzi.zip
(74.38 KiB) Downloaded 363 times
osmat
Admin
Post by osmat »
iparos wrote: 04 Jul 2019, 14:00
Tools Not yet perfect. In his work there are significant improvements. Try to create additional images for the items you need.
Stupidiputs
Is there any manual in this community about how to edit json files? I dont know what some variables mean.
osmat
Admin
Post by osmat »
Stupidiputs wrote: 05 Jul 2019, 09:53
We are preparing the most complete information that we have today and will soon publish it.
alberstelar
Post by alberstelar »
CAN ANYONE HELP ME?
I've been wanting to edit an animated bin file (nyan cat and also the pikachu one) and as I do with the other bins, I replace the images with the ones i want. But my problem is that when I compress the edited items into the new bin file the bin file weights around 1mb when it should be 300kb, its not because i used hq images or anything, cause i also decompress any kind of animated bin and compress it again without changes and ends up around 1mb as well. What's happening? can anyone tell me? pls.
CescP.
Post by CescP. »
Hello!
I've created a custom WatchFace with the PlayStation Logo, I have followed the instructions, but after all, in my Mi Band 4 doesn't appear PlayStation Logo, only the black background, Time, Date, etc.
Can you help me?
Has thanked: 1139 times
Been thanked: 276 times
Users browsing this forum: Google Adsense [Bot] and 2 guests
