manage and show watch faces(WFZ) with mac computer
Peterdee
Post by Peterdee »
Hi to all.
I like to open, and manage my Stratos watchfaces on my MAC computer.
I do NOT having any problems to transfer downloaded wfz to and from my Stratos by using: "Android File Transfer"
My problem is that hat some of the wfz has a clear file name and some just fo example: 5ce245ba87fad_20052019.wfz.
The watch only shows clear name of the watch face and NOT: 5ce245ba87fad_20052019.wfz
And on the file overview of the "Android File Transfer" it shows both, some as clear name, some like: 5ce245ba87fad_20052019.wfz.
But with that, I can not identify which is what.
So I am looking for an application or any way wich can open the file like: 5ce245ba87fad_20052019.wfz on my mac to make me able to identify the watch faces.
Then I can select wich wfz I want on my watch and wich I like to store on my mac for later use.
Thank you for reading.
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
Peterdee wrote: 30 Jun 2019, 05:43
Hi to all.
Hello. You can open them with any archiver.
Peterdee
Post by Peterdee »
Thank you very much for you quick reply.
What is an "archiver"?
What is the proper program with a Mac computer for this?
Regards
Has thanked: 1181 times
Been thanked: 281 times
Peterdee wrote: 02 Jul 2019, 23:42
Regards
https://www.keka.io/en/
osmat
Admin
Post by osmat »
Regards
Mac OS supports native archives in zip format. Just change .wfz to .zip
Peterdee
Post by Peterdee »
Thank you for your reply.
I have done this with a result that since I use a "archiver" i can unpack and see all files in it.
Yes, somewhere in a text, there is shown the clear name of the watch face and i can identify he watch face than.
But after this the watch face is not useable anymore because after that the computer store it that as a file folder and not as watch face (WFZ) anymore.
So it is not really a solution.
osmat
Admin
Post by osmat »
Soon we will release our application for iOS in it will wake up the ability to delete watch face
Peterdee
Post by Peterdee »
Super,
thank you very much.
I and I am sure a lot of other Stratos users will looking forward to this.
regards
Peter
