• Administrador
Bip Question
Topics about Amazfit Bip series watches and all the questions regarding their use, etc.
Moderadores: asoo, Watchmens
Reglas del Foro
For example: Screen timeout question [Bip U]
Responder
Fuisonpower53
Contactar:
Bip Question
Mensaje por Fuisonpower53 »
Hi, I'm very new and am planning to buy an Amazfit Bip3 but I want to install a specific watch face on it. however, before I buy I was wondering if I use a watch face that says it's for Bip downloaded from this site will I be able to download it and install on the Bip 3 or is it only meant for the first edition of the watch or would I be able to install it on the watch?
Avatar de Usuario
Been thanked: 2122 times
Mensaje por asoo »
In the Bip category you can use the Filter to select only Bip3/Bip3pro. Once you have applied the Filter you will see watch faces that can be used with Bip3.
Other Bip models cannot be used with Bip3.
link filter only Bip3 / Bip3pro
https://amazfitwatchfaces.com/bip/fresh ... ible=Bip_3
Responder
Volver a “Device discussion”
¿Quién está conectado?
