Hi.
I have an Amazfit T-Rex Pro, and recently I created my own watchface. Although it does work quite good, there is something wrong with sunset and sunrise reading. While it's sunset, it shows normally as sunset. But when time changes to sunrise, it doesn't change. It stays at sunset until a length of time. On the morning when it's 7:00 o' clock, it shows sunrise time to be like 7:43, but the image stays sunset. I no longer know what to do anymore. I've tried everything. I renamed the 2 images to 1 and 2, doesn't work. I tried to change it to sunset and sunrise, still doesn't work. I tried to change it to uniform to independent and vice versa, still doesnt work. I've tried to delete and reinstall the images, still doesn't work. Maybe is it because the images are bigger than previous ones which was smaller? But I don't see it as a case since it does work on greater size image as well. Is it image format? What is it? With the device there is not a problem, because I tried other watchface too. It's working perfectly. But in my one, it doesn't. Please... Help me to solve this problem. Please and thanks.
Amazfit T-Rex Pro Watchface issue
Paul_Moysidis_98
