Xiaomi S1 Active
Discussions on other topics.
Andandre
Xiaomi S1 Active
Post by Andandre »
Hello. Is there watch face for Xiaomi S1 Active? Is it possible to create or edit the watch face of the Xiaomi app for the S1 Active?
Ola. Existe watch face para o Xiaomi S1 Active? É possivel criar ou editar as watch face do aplicativo da Xiaomi para o S1 Active?
https://www.mi.com/global/product/xiaom ... s1-active/
Andandre
Post by Andandre »
Thank you for your help!
I don't think anything about this watch. This watch is a 2022 release.
If anyone can help about watch faces for him. Or if it is possible to edit the watch faces that you have in his app.
Thanks.
Xiaomi Watch S1 Active:
Andandre
Post by Andandre »
Does anyone know if it's possible to create or edit some watch face?
Nenad
Post by Nenad »
And I am looking for an answer to that question !!! I saw on the telegram group that it has a MiFit application mode and that it has 400 watch faces, but I soon realized that there are 200 global and 200 of the same only in Chinese and a couple in Russian. All in all, I did not find anywhere that S1 and S1 active have the ability to download watch faces by third-party applications, as well as the ability to create your own. I'm sorry about this because the watch is good, but it lacks that costume design and choice of watch faces. If more people were looking for that possibility, maybe Xiaomi would do something about it. If I find out anything in the meantime, I'll let you know.
Andandre
Post by Andandre »
Nenad wrote: 14 Jun 2022, 15:12
deepblue2000
Post by deepblue2000 »
I wanted to buy the "Xiaomi Watch S1" too,
but I saw that there are no custom watchfaces yet...
so I will wait
mmx233
Post by mmx233 »
I am also waiting for Xiaomi S1 compatibility. I thought it is granted from the start, as it is a family member of Huami watches as well.
In case you need some testing just let me know, I would gladly cooperate.
Thanks in advance.
Has thanked: 1147 times
Been thanked: 276 times
mmx233 wrote: 03 Nov 2022, 22:35
Thanks in advance.
First, we need dials. If you have, please share.
3amo4ek
Post by 3amo4ek »
Жду з нетерпінням коли ви зробити для них кастом циферблати! ;)
Andandre
Post by Andandre »
Still not possible to create or edit Xiaomi watchface for S1 Active?
Andandre wrote: 14 Mar 2023, 19:07
No change, unfortunately.
mmx233
Post by mmx233 »
GIK-Team wrote: 03 Nov 2022, 22:53
Thanks in advance.
Sorry for the late reply. What do you mean by "dials" and how can I share it?
What else can I share to help the development?
mmx233 wrote: 02 Apr 2023, 12:19
Thanks in advance.
dials aka watch faces
mmx233
Post by mmx233 »
GIK-Team wrote: 02 Apr 2023, 14:47
You can download all my current watchfaces for 21 days from here:
https://filetransfer.io/data-package/QGx3X1OV#link
Please let me know if you succeeded to download them. Thanks.
mmx233
Post by mmx233 »
Original location of the folder is
/storage/emulated/0/Android/data/com.xiaomi.wearable/files/WatchFace
mmx233
Post by mmx233 »
mmx233 wrote: 02 Apr 2023, 15:54
Have you downloaded it?
mmx233 wrote: 15 Apr 2023, 06:05
Yes, but it gave nothing because nothing is clear.
mmx233
Post by mmx233 »
Thanks for the feedback.
In case I can help you trying out some ideas just let me know.
Unfortunately I still cannot reach the Xiaomi server to download any new watchfaces.
swr85
Post by swr85 »
There is a Russian dev who made a wonderful app with plenty of watches, look for m0tral apk
swr85
Post by swr85 »
mmx233 wrote: 02 Apr 2023, 15:58
Dear, What soft do you use to design the watchface?
mmx233
Post by mmx233 »
I just downloaded them using the only supported application: MI Fitness.
About the m0tral apk: Thanks for mentioning. The program lists Xiaomi S1 compatibility, so I will try it.
mmx233
Post by mmx233 »
mmx233 wrote: 23 Apr 2023, 20:44
I had to use my rusty Russian knowledge to download it (probably there are English sources too), but it did worth to install as it upgraded the firmware of the watch, too. Upgrading was quite slow, cc half an hour. There are downloadable custom watchfaces! Thanks swr85!
Image Image Image Image Image Image
GIK-Team It means m0tral knows the format of the watchfaces and the protocol used. Maybe you should contact him/her.
elpe
Post by elpe »
Is there any chance that S1 / S1 active will be added?
elpe wrote: 18 Sep 2023, 09:53
We regret to inform you that there's a low likelihood of adding support for the S1/S1 active. This is because we haven't received any information regarding watch faces for this model for a considerable period of time. We appreciate your understanding.
Return to “Off-Topic”
