Se encontraron 4 coincidencias
- 14 Jun 2022, 15:12
- Jump to forum
- Jump to topic
Re: Xiaomi S1 Active
And I am looking for an answer to that question !!! I saw on the telegram group that it has a MiFit application mode and that it has 400 watch faces, but I soon realized that there are 200 global and 200 of the same only in Chinese and a couple in Russian. All in all, I did not find anywhere that S1 ...
- 05 Oct 2020, 11:46
- Jump to forum
- Jump to topic
[Tutorial] How to create WFZ watchfaces for Stratos 3 (new style / GTRWidget)
Hello community,
I've been asked several times how I do it with the watch faces and what software I use. The Software-question is easy to answer: Paint Shop Pro 2020 for the graphics, Notepad ++ for the code and 7zip to pack / unpack. Nothing else.
For the HOW-question - I sat down and wrote the ...
- 05 Oct 2020, 11:47
- Jump to forum
- Jump to topic
Re: [Tutorial] How to create WFZ watch faces for Stratos 3 (new style / GTRWidget)
Table of contents
THE BASICS
Structure of the basic files
Special configurations in the base files
Structure of the "font.xml" file for displaying digits and characters
THE ELEMENTS
WatchFaceItem elements
WatchFaceComponent elements
Explanations of the parameters for the ...
THE BASICS
THE ELEMENTS
- 17 Nov 2020, 15:26
- Jump to forum
- Jump to topic
How to install watchfaces (Amazfit X, Amazfit Band 5)
Detailed instructions for installing custom watch faces on
Amazfit Band 5 and Amazfit X smart bracelets.
Note! At the moment, the instruction is relevant only for Zepp
For a successful installation, you need to connect your gadget to a smartphone on Android with the Zepp app installed. You ...
