- Amministratore
help dowload watchfaces
Hello, how do I download a watch face for Amazfit T Rex 2 , I click on Dowload but it does not let me download anything, help me ?? Thank you
- GIK-Team
- root
- Has thanked: 1151 times
- Been thanked: 278 times
- Contatta:
Where are you and what are you downloading?Armo96 ha scritto: 03 gen 2023, 18:12Hello, how do I download a watch face for Amazfit T Rex 2 , I click on Dowload but it does not let me download anything, help me ?? Thank you
Pit-Smoker
- Contatta:
It's a pain in the neck. First go right into the watch on your wrist. Press and hold the face, and you should be able to enter the watch faces area. Now on my TREX Pro, there are 5 faces in there. You want to delete one by sliding it up. That will remove it from the watch. Sadly, I can only delete 2-- not the factory ones.
After one face is deleted, you SHOULD (should! I hope!) Be able to download the one you want from here. After that download and "sync" it will magically appear on your wrist.
Hope that helps, and I hope it's accurate for your model.
