How to make sample watchface images
VergeUser
I have developed some watchfaces for Verge at the Simple Amazfit Watchface Builder website, but the problem is that that website does not support some widgets that the Amazfit Verge supports. Moreover, widget placements on the verge are different from that on the Stratos because of the different screen resolutions. So, when I try to get a sample watchface image at that website, either the image contains all the widgets, but everything is off-center and skewed, or even worse, sometimes the image does not include some widgets at all. Is there some other website at which I can import a wfz file that will generate an accurate preview for me that I can then include in my wfz as a sample image? Thank you.
- GIK-Team
- root
- Has thanked: 1172 times
- Been thanked: 281 times
At the moment there is no working tool.VergeUser wrote: 10 Apr 2019, 20:58Hi,
georgejones01
VergeUser
So, how do other users here create and post their watchfaces. The couple of faces I have shared here it took me a while to get a preview that looked decent. I have created other faces that I am simply unable to share. There has to be some solution that others are using.
- chb
- Has thanked: 10 times
the WF-Maker-tool from VIzzAR looks very nice!
But i don't understand why there are so many options (color, font, size) only for digital time, but not for date and weekday...
Don't worry, eat Curry!
- osmat
- Admin
- Has thanked: 35 times
- Been thanked: 73 times
In a short time we will prepare for you a complete description of all the possibilities. A digital clock is a font converted into boxes. Date is a widget sewn into the firmware. Today there are only 12 options for the date widget
