Amazfit Band 7 Watchfaces
Модератори: Internal error, Watchmens
Закрито
f4bulous
З нами з: 11 листопада 2022, 01:32
Контактна інформація:
Повідомлення f4bulous »
Hello!
I'm looking for some Amazfit Band 7 (do not mistake it for the Xiaomi Mi Band 7) custom watchfaces but i can't find it anywhere.
Are you guys planning on adding Amazfit Band 7 support on your website/app?
Also, i've noticed that the Honor Band 6 has the same resolution as the Amazfit Band 7, maybe you can merge the 2 bands as a single category?
Аватар користувача
З нами з: 22 березня 2018, 10:00
Has thanked: 1184 times
Been thanked: 281 time
Повідомлення GIK-Team »
f4bulous писав: 15 листопада 2022, 04:08
Hello!
Hello! We plan to add this model to the catalog as an addition to Mi band 7. This will happen in the near future 1 - 3 days. ;)
Аватар користувача
f4bulous, we have added a new section. We are waiting for new dials to be added to it.
f4bulous
GIK-Team писав: 15 листопада 2022, 16:38
@f4bulous, we have added a new section. We are waiting for new dials to be added to it.
Nice! I'll start uploading some watchfaces soon, tho i find it weird to put the Amazfit Band 7 catalog as an addition to Mi band 7, since they have different resolutions (Mi Band 7 is 122px taller).
Thanks for the reply!
Аватар користувача
f4bulous писав: 15 листопада 2022, 16:51
We know, but we can’t separate them yet, because we don’t really understand how many dials will be added.
Аватар користувача
f4bulous
We have separated the Amazfit Band section. Your watch faces have been moved to a new section of the site.
trogoz
З нами з: 21 листопада 2022, 11:11
Повідомлення trogoz »
Hi!
I am happy to see the new section, but there are no specific instructions for installing watchfaces on the amazfit band 7. On pc the files are .zip, not .bin so the susbstitution trick is not the way to go (I guess?).
The app does not allow installation in android 12, it stops right after you tap on "install", the bar never fills. I also tried the basic bt/permissions/app reset, no luck
Аватар користувача
trogoz писав: 21 листопада 2022, 11:17
Hi!
Hello! What version of the app?
trogoz
GIK-Team писав: 21 листопада 2022, 12:15
Hi!
This is 3.9.262 , i tried both on a Xiaomi mi 11 lite 5G, and an Oppo find x3 pro, both android 12
Аватар користувача
trogoz писав: 22 листопада 2022, 08:51
Update to latest 3.9.268
trogoz
Omfg thanks man it worked!
I had to re-synchronize with Zepp app and now the download process proceeded. I installed the watchface now, thanks!
I am really happy with this, now I have to learn to develop my own faces and post them on the website! 🤩
THANKS!
Закрито
Повернутись до “Closed topics”
Хто зараз онлайн
