Amazfit Band 7 Watchfaces
f4bulous
- Has thanked: 4 times
- Contactar:
Hello!
I'm looking for some Amazfit Band 7 (do not mistake it for the Xiaomi Mi Band 7) custom watchfaces but i can't find it anywhere.
Are you guys planning on adding Amazfit Band 7 support on your website/app?
Also, i've noticed that the Honor Band 6 has the same resolution as the Amazfit Band 7, maybe you can merge the 2 bands as a single category?
- GIK-Team
- root
- Has thanked: 1184 times
- Been thanked: 281 times
- Contactar:
Hello! We plan to add this model to the catalog as an addition to Mi band 7. This will happen in the near future 1 - 3 days.f4bulous escribió: 15 Nov 2022, 04:08Hello!
- GIK-Team
- root
- Contactar:
f4bulous, we have added a new section. We are waiting for new dials to be added to it.
f4bulous
- Contactar:
Nice! I'll start uploading some watchfaces soon, tho i find it weird to put the Amazfit Band 7 catalog as an addition to Mi band 7, since they have different resolutions (Mi Band 7 is 122px taller).GIK-Team escribió: 15 Nov 2022, 16:38@f4bulous, we have added a new section. We are waiting for new dials to be added to it.
Thanks for the reply!
- GIK-Team
- root
- Contactar:
We know, but we can’t separate them yet, because we don’t really understand how many dials will be added.f4bulous escribió: 15 Nov 2022, 16:51Nice! I'll start uploading some watchfaces soon, tho i find it weird to put the Amazfit Band 7 catalog as an addition to Mi band 7, since they have different resolutions (Mi Band 7 is 122px taller).
- GIK-Team
- root
- Contactar:
f4bulous
We have separated the Amazfit Band section. Your watch faces have been moved to a new section of the site.
Hi!
I am happy to see the new section, but there are no specific instructions for installing watchfaces on the amazfit band 7. On pc the files are .zip, not .bin so the susbstitution trick is not the way to go (I guess?).
The app does not allow installation in android 12, it stops right after you tap on "install", the bar never fills. I also tried the basic bt/permissions/app reset, no luck
- GIK-Team
- root
- Contactar:
Hello! What version of the app?trogoz escribió: 21 Nov 2022, 11:17Hi!
This is 3.9.262 , i tried both on a Xiaomi mi 11 lite 5G, and an Oppo find x3 pro, both android 12GIK-Team escribió: 21 Nov 2022, 12:15Hello! What version of the app?trogoz escribió: 21 Nov 2022, 11:17Hi!
- GIK-Team
- root
- Contactar:
Update to latest 3.9.268trogoz escribió: 22 Nov 2022, 08:51This is 3.9.262 , i tried both on a Xiaomi mi 11 lite 5G, and an Oppo find x3 pro, both android 12
Omfg thanks man it worked!
I had to re-synchronize with Zepp app and now the download process proceeded. I installed the watchface now, thanks!
I am really happy with this, now I have to learn to develop my own faces and post them on the website!
THANKS!
THANKS!
¿Quién está conectado?
