Request watchface for GTR2
Hello to community, can someone help me to port this watchface for our GTR2 because I'm short-sighted and I'm looking for watchfaces with larg fonts. Please make it as it is and replace floors with weather and add analog or digital seconds and am, pm, 24h icons. Thank you.
- rush2112
- Has thanked: 121 times
- Been thanked: 10 times
I did try to make this face watch but know success trying to put this gtr3 to a face watch gtr2 having errors, don't know what I'm doing wrong I did starting
0001 icons ..... at the end building the json after creating the .bin I'm receiving errors I need help to see what I'm doing something wrong, can you tell me what I'm something wrong thanks
- Has thanked: 438 times
From the information you said, I can't summarize either.rush2112 wrote: 06 Oct 2022, 10:14@asoo
0001 icons ..... at the end building the json after creating the .bin I'm receiving errors I need help to see what I'm doing something wrong, can you tell me what I'm something wrong thanks![]()
SO what error, please show your error message you receive from program to me.
Or zip your work and attach in post.
RTMhun
- Has thanked: 2 times
- Been thanked: 11 times
here is mine
https://amazfitwatchfaces.com/gtr/view/28116
as you requested: Big numbers, seconds, am/pm indicator, temperature and weather icons are on the face
unfortunately the weather layer isn't able to stay background -
that's why I didn't put it in the center
Many thanks to the creators for the effort to make this watchface but have no dnd, connection, lock and alarm icons at all, some of the fonts are wrong like the steps and they fall on the time and some others fall on numbers and GTR 2 doesn't support floors and I don't even know what this percentage is. Thanks anyway. Thank you guys for the effort.I see this watchface is already made for the GTR3 so if someone experienced creator could simply port it as it is for the GTR3 Pro version that would be just great. Thank you.Thank you and I will not be asking for help for the same watchface again. You have helped me so many times in the past.
RTMhun
O.K.
I'll upgrade it.
in your post what I read didn't ingredient dnd, connection, lock and alarm icons.
until now I didn't know the original gtr3 face, only what you linked (a samsungwatch pic)
my solution same as it.
but I will correct my version to needed - for other people, who download it further.
nothing problem. it was my first try to satisfy a wish.
I am happy, 'cause it success.
I'll upgrade it.
In my opinion, the work you ported is very good port.RTMhun wrote: 08 Oct 2022, 11:46O.K.
I'll upgrade it.
I'm cheering for your work. Your work is of good quality.
And thank you for your help in this community.
Thank you, RTMhun and rush2112 for support and help. Keep up the good port.
RTMhun
pls check newer version!petroula wrote: 07 Oct 2022, 11:04Many thanks [...] but have no dnd, connection, lock and alarm icons at all, some of the fonts are wrong like the steps and they fall on the time and some others fall on numbers and GTR 2 doesn't support floors and I don't even know what this percentage is. Thanks anyway. [...]
it has dnd, bluetooth, lock and alarm toggle icons;
has an editable zone to move weather 3 position;
steps counter has stepped left a bit yet
the icon on bottom (like a stairs shape) shows PAI but I don't know what unit has it... not percent? ok.
I added two indicator bars to display decrases of battery and calories...
good luck bro!
