How to install watchfaces (Bip, Verge Lite, GTR, GTS, T-Rex, Cor, Mi Band 4)
Moderatori: asoo, Internal error
Has thanked: 1161 times
Been thanked: 278 times
Messaggio da GIK-Team »
Detailed instructions for installing custom watch faces on Amazfit GTR, GTS, T-Rex, Verge Lite, Amazfit Bip smartwatches, and Cor and Mi Band 4 smart bracelets.
Note! At the moment, the instruction is relevant only for Zepp (Amazfit)
For a successful installation, you need to connect your gadget to a smartphone on Android or IOS with the Amazfit (Zepp) app installed. You also need to have installed file manager and pre-download the watch face that you would like to set on your watch.
Installation for Android
  1. First, you need to install one of the stock watch faces available in Zepp (Amazfit)/Mifit (if you have already installed one, you may skip this step).
  2. Open the folder with the downloaded watch face in the file manager with the path:
    • Zepp (Amazfit) /Android/data/com.huami.watch.hmwatchmanager/files/watch_skin_local/
    • Mi Fit /Android/data/com.xiaomi.hm.health/files/watch_skin_local/
  3. Go to any of these folders and find the .bin file. Copy the .bin file name.
    • Name example for bin: 4lIYUjzg3Vwqt8tJU9sYLeOSqUSAreJNzUxJhxgM.bin
    • Name example for zip: UQkNrGEQmaPvYbLmGseWkOkUCHDDkOBf.zip
  4. Go to the custom watch face and rename it using the name of the standard watch face.
  5. Copy the watch face file with the new name and transfer it to the folder from step 3 with a replacement.
  6. Open the Zepp (Amazfit)/Mifit app and install the stock watch face, which file you replaced.
Android apps
AmazFaces app
Gadgetbridge (Android)
Notify & Fitness for Amazfit (Android)
Amazfit Replacer (Android)
Installation for iOS
You may also use our application or other, such as AmazTools (iOS), to install watch faces
This manual is current at the time of writing.
If you notice any inaccuracies or mistakes, please, let us know.
knorde
Messaggio da knorde »
GIK-Team ha scritto: 18 nov 2021, 17:22
knorde ha scritto: 18 nov 2021, 15:00
I have the zepp app, don't see the pad in the file manager.
Is this working in the zepp app and is the GTR 2(e) supported by this?
Gadgetbridge: Link not working.
Notify & Fitness for Amazfit: No option for uploading .bin to smartwatch.
Amazfit Replacer: This is only voor bip, not for gtr 2(e).
knorde ha scritto: 18 nov 2021, 17:57
https://gadgetbridge.org
~3min
knorde
It works (i have done it with Notify & Fitness for Amazfit), thanks a lot for all the help!
Sorry, its all new for me, i'm very happy now :)
ferno
Messaggio da ferno »
I have created a guide for CREATING and INSTALLING watch faces for Bip-U, since I did not find anything published for this Amazfit model:
https://gist.github.com/fernospam/b0339 ... 4c94c511e6
also in spanish:
https://gist.github.com/fernospam/b0339 ... t-bip-u-md
I would like to thank user dAnnRioja for his huge help on preparing this guide.
I hope it is usefull for the community.
Ihavenoclue
Messaggio da Ihavenoclue »
When trying to UPLOAD - as per video - there is no option to download to phone / file manager is what he probably meant as I also have no option to store on phone. Only options to chose from is the notify app. However, this wont install the watchface... :?:
gilardino86
Messaggio da gilardino86 »
He estado probando y no funciona este metodo para mi amazfit gts 3. ¿Alguna solucion?
Иван Кулишов
Messaggio da Иван Кулишов »
Как установить тему на T-Rex с 11 андроидом????? Все же работало, зачем было все портить???? Приложение стало бесполезно(((((((((
Иван Кулишов ha scritto: 23 feb 2022, 14:22
Что работало??????? Кто испортил?????? Какое приложение??????
А если серьезно, то нормально опишите, что у вас и где не работает и о каком приложении идёт речь. Здесь не россия, цивилизованные люди так не общаются.
Иван Кулишов
GIK-Team ha scritto: 23 feb 2022, 15:49
А что не понятно я написал? Как установить на T-rex с 11 андроидом? При нажатии на отправить на часы, ничего не происходит
Иван Кулишов ha scritto: 28 feb 2022, 05:51
Слушай сюда, ты или нормально напишешь или пойдешь туда же куда и русский военный корабль. Не ясно где ты там и что нажимаешь. Какое приложение, какая версия?
snapmp3
Messaggio da snapmp3 »
Hi there,
Is there any way to install directly my own created watch face using my iPhone or my AW without public or verified by website administrator? That's allow watch face maker to have the possibility preview the watch face immediately.
Thanks.
I am using AW tool for GTS3 via iPhone.
josecdv95
Messaggio da josecdv95 »
snapmp3 ha scritto: 30 mar 2022, 03:53
Hi there,
Thanks.
Hello guys, I have the same question, is there any way to install watchface using Amazfaces without upload the zip to this website in iOS?
Or at leas let us install watchfaces while is "ONMOD" because we can not test it :/
The app amazTools is not working for me, I can only upload bin files not zip :(
Thanks.
wbshrk
Messaggio da wbshrk »
These instructions no longer work as of today the Zepp app does not use the watch_skin_local/ for the GTR3. it seems to pull the file from the zepp cloud each time.
Been thanked: 2120 times
Messaggio da asoo »
wbshrk ha scritto: 19 mag 2022, 15:08
Which version you encountered this problem?
I am currently using Zepp Version 6.9.2-play.
I can also use zepp to upload watchface from Folder watch_skin_local/ xxx/ to my watch GTR3 normally
I test again :
After removing all the watch faces and doing re-download will not be able to use the same method again.
Please try this app (android)
Amazfit GTS 3 GTR 3 Pro Faces
https://play.google.com/store/apps/deta ... fitwatches
Program can direct sync to watch
dpavao
Messaggio da dpavao »
Hello, has anyone had any luck installing watchface on a GTR? I have tried for hours and literally nothing works. Android device 12.(something). Very frustrating. Tried to replace file with pc as well. Will not work. Help!
Caniwi
Messaggio da Caniwi »
With the new app update I can now no longer install by replacing the standard dial as an option? How do you install now on the GTR?
Giampietro
Messaggio da Giampietro »
Dopo aggiornamento impossibile installare nuovi quadranti, aiuto!
Gtr3 pro non si connette.
ChaliDo
Messaggio da ChaliDo »
I love one of the wallpapers which is : https://amazfitwatchfaces.com/mi-band-4/view/15449
But is there an any way to change it's language? English at least?
Evilmind_04
Been thanked: 14 times
Messaggio da Evilmind_04 »
As of today it's not possible to replace the original wf on the GTR3 Pro.
I kept searching for a new location but can't find it.
Also there is a new text under the original faces, it says free.
If they actually gonna do this they are going after huawei's method and we need a cracked version of the Zepp app and have to be ready for payed watchfaces.
I guess they need more income?
I hope I am wrong but it doesn't look like it for now.
Machi007
Messaggio da Machi007 »
I figured out how to install custom watch faces on GTR 2, tested on Android 11 with latest Zepp app from Google Play Store. But you must be rooted...
Install Root Explorer and go to this path:
Codice: Seleziona tutto
/data/user/0/com.huami.watch.hmwatchmanager/files/watch_skin_local/
Here you can replace original downloaded watch face with custom one.
Finally synchronize using Zepp app and you are done! 8-)
gnokketto
Messaggio da gnokketto »
the istruction is too old not working now... anyone have updated info ?
(T REX PRO)
ItRainsSmiles
Messaggio da ItRainsSmiles »
Hi guys,
I struggle quite a bit to load a custom watch face on my Mi band 7.
Here the steps I did:
  • Connected the Android phone, which had the new Mi Fit app installed, to the laptop.
    Went to /Android/data/_the_mi_app_/watchfaces/ and switched the current installed watchface with the custom watchface. - (renamed the original, the custom one had the naming from the original)
    Synchronized the watchface from the app to the watch - Same original watchface, not the new one.
  • Installed the Zepp life app and deinstalled the new mi fit app from the android phone.
    Also resettet the watch and loaded a couple of watchfaces to the watch.
    Connected the android phone with the laptop, went to /Android/data/com.xiaomi.hm.health/files.
    No "watch_skin_local" folder there, so I created one, created an additional folder and pasted the custom binary there.
    Restarted the app, no "Local watch faces" tab there.
    The app seems to only store the watch faces online, no watch faces cache on the phone, nothing.
    I disconnected the Mi Fit account within the app and switched watch faces.
    I went to airplane mode but activated bluetooth again.
    Was not able to enter the "store", no _local_ watch faces were shown ether. - Also not within the "watch_skin_local" folder.
  • Installed the AmazFaces app for android.
    Set the Mi Band 7 visable for incoming BT connections.
    Made the proper in app configurations regarding permissions, (BT)Mac adress, using app and enabled all background permissions.
    Selected a custom Mi Band 7 watchface from the AmazFit app, (tried this with a few ones), clicked on "download".
    As soon as the app connects to the Mi Band 7, the app crashes (minimizes itself and backs out of the connection tab).
    Tried this with the Zepp life app in background and with the Zepp life app closed.
    Also factory resetted the Mi Band 7 between each app installation / deinstallation circle.
Is there a proper way to load custom watch faces to the Mi Band 7 that I have not tried yet?
I used the latest app versions of every used app on Xiaomi Redmi Note 9 Pro, Android 11 and have the latest firmware on the Mi Band 7 (EU version(?)).
Thanks a ton!
Kind regards,
David
ItRainsSmiles
Okay, I got the Mi band 7 to work with custom watchfaces using the older Zepp Life v 6.2.1.
Finally, supported local bands again :)
wolliden
Messaggio da wolliden »
ItRainsSmiles ha scritto: 03 set 2022, 16:15
Thanks for this advice.
Is it safe to update ZL to >6.2.1 and still working local folders?
AW App Android 3.6 still crashes when trying to download watchfaces. Manual install works. Pixel 6 Pro A13 no root.
ItRainsSmiles
wolliden ha scritto: 12 set 2022, 08:40
You're welcome :)
When you update from ZL 6.2.1 to a more recent version, the custom local stored watchfaces won't be accessable through the zepp life app, but they are still stored on the watch.
I updated to the recent version, bought some watchfaces from the store and synched them to the watch.
Uninstalled the zepp life app, Installed the version 6.2.1 and loaded some custom watchfaces to it (manually, not through the AW-app - that crashes.
This way it is possible to have both, the bought watchfaces and also the custom watchfaces on your watch.
Greetings
Torna a “Manuals and instructions”
Visitano il forum: Nessuno e 10 ospiti
