- Administrador
I'm working on a new Xiaomi Band tool and need your advice.
Regras do fórum
Hello, I'm working on a new Xiaomi Band tool recently. It is based on go language, supports MacOS, windows and Linux systems, and may also work on Android phones.
Moreover, it will be open source.
Functions currently being implemented:
0. Generate the preview file of the dial from the JSON file.
Next, we intend to realize some basic capabilities:
1. Parse bin file to JSON file.
2. Support MI4 - 6 all devices.
Future plans:
3. Enrich the generation of preview pictures. For example, it can be directly converted into GIF moving pictures, or it can modify the time, weather, steps and other information to generate different preview pictures.
4. Support dial editing (this is a relatively large project).
5. Support more types of devices, such as Huawei bracelets.
Which function points do you think are the most attractive?
You can reply to the number of functions you most expect, which I will use to determine the priority of future development.
If you have other functions you feel you need, you can also leave a message.
If you are interested in participating in the development, please also contact me. https://t.me/d4x1o
At present, I need a UI / UX designer to help optimize the presentation of the app.
A screenshot of the app is attached.
Future plans:
- shrewdroid
- Registrado em: 02 Abr 2022, 09:00
- Been thanked: 2 times
- Contato:
Best of luck dude .. m sure this will help a lot of us!
What is your most anticipated feature? Or what you need most?
I want this software to play its own value, so I need your advice.
franluciani
- Registrado em: 04 Out 2019, 16:55
- Has thanked: 9 times
- Been thanked: 6 times
- Contato:
Hi, i did some faces to Mi Band 4 and 5. But there's some things that i can't do with the actual tool. Will be great manage the order of the layers, for example draw in hours, the tens front and the ones at back, to covering with the tens some areas to ones. Other thing that will be great is use the secconds, because they are not working properly in mi band 4 and 5.
itaketapps
- Registrado em: 01 Ago 2022, 09:30
- Contato:
Good day. Very important, in my opinion, is the ability to create working analog dials. The MiBendWatchFaces program has such a function, but after packaging the Bin, the created watch disappears, although it is displayed in the preview.
Everything will be Ukraine
tute123456
- Registrado em: 13 Jun 2023, 18:05
- Has thanked: 1 time
- Contato:
release day?
Xiaomi - Mi band 6
FW Stock
FW Stock
Quem está online
