• Administrador
Please Convert Watchface [GTR 47mm to GTR 3 Pro]
Moderadores: asoo, Watchmens
Regras do fórum
hopter
Registrado em: 21 Mar 2022, 08:50
Contato:
Mensagem por hopter »
Hi Asoo
If you have time, could you be so kind and convert RZ241 (3 color versions) Watchface from GTR 47mm to GTR3 Pro ?
https://amazfitwatchfaces.com/gtr/view/20343
https://amazfitwatchfaces.com/gtr/view/20344
https://amazfitwatchfaces.com/gtr/view/20345
Thank You!
Avatar do usuário
Has thanked: 411 times
Been thanked: 2050 times
Mensagem por asoo »
Please select one color you want . I will do it for you
Ps.
if possible the next time if you request in community please do not be specific my name , you can request by use "Somebody or Someone can help me about ......" if i can and i interest i will do it. Do not specify the person's name. Because there may be other people who may be interested in helping you with your request besides me.
hopter
Contato:
Green version:
Thanks in advance!
PS: Ok, i understood.
Avatar do usuário
Mensagem por asoo »
Imagem Imagem
RZ241Green_FAOD_GTR3.zip
(243.12 KiB) Baixado 110 vezes
RZ241Green_FAOD_GTR3Pro.zip
(298.5 KiB) Baixado 100 vezes
1. This watchface in Pro version not test on real device. it's only tested on program editor
link program editor : viewtopic.php?p=11643#p11643
hopter
Contato:
Perfect, thank you again!!
kotobuki09
Registrado em: 28 Nov 2021, 17:36
Contato:
Mensagem por kotobuki09 »
Thanks, asoo ! I want to covert other versions as well. What tool are you using to extract all the files for GTR 47mm?
Avatar do usuário
Mensagem por asoo »
kotobuki09 escreveu: 27 Mar 2022, 12:40
Thanks, @asoo ! I want to covert other versions as well. What tool are you using to extract all the files for GTR 47mm?
Program editor GTR47mm can extract it.
Link Porgram :
viewtopic.php?t=1076
kotobuki09
Contato:
asoo escreveu: 27 Mar 2022, 13:18
Link Porgram :
I see that you have to redesign with a new wallpaper size!
Avatar do usuário
Mensagem por asoo »
kotobuki09 escreveu: 27 Mar 2022, 14:30
Link Porgram :
you can use image after extract to built GTR3 after finish you can convert to GTR3pro by use function convert in program "Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3)"
Imagem
viewtopic.php?t=2743
kotobuki09
Contato:
asoo escreveu: 28 Mar 2022, 03:43
Link Porgram :
Imagem
Thank for the tip!! :) that's actually much better approach
Responder
Voltar para “Watchfaces creation (order table)”
Quem está online
