Need help RZ228 for GTR2
- alexstam78
- Has thanked: 173 times
Hello to community and Happy New Year to all, can anyone from creators port this amazing watchaface exactly the same for GTR2 and add weather. Many thanks to the community and the creators for all the requests they have made and will make. Many thanks to asoo for his help and support and to Feru who makes RZ series. Many thanks to Rcappa for RZ229 request Thank you and Happy New Year with health to all.
https://www.facer.io/watchface/hK0xVO8s ... laxywatch3
- Has thanked: 411 times
- Been thanked: 2050 times
I think the technique of making it is the same as the previous one. I don't think it's too difficult for GTR2's "Watchface Maker".
So this watch face i am not interested to port.
Ps. If this could actually be done in the GTR2, I think the second spin. must be less wide and the battery progress will be move the other area . Or change the second spin to other progress , Ex. Change to use "image progress" for ( Step )
Bye Good Luck
13-01-2022
I've tried a rough port test, I don't think it's possible in GTR2 because if I'm not mistaken. The GTR2's second hand is always displayed at the top.
From the picture, it can be seen that the separator cannot be used to cover the parts that do not want to be displayed. Because that area still needs to be used work by another element
And if it does possible, it must be make 60 images to be displayed the seconds element . Which probably doesn't use the reason that should have done it.
This is just my opinion only.
Bye Good Luck
13-01-2022
- alexstam78
I think this has the same filosofy as the previous. Let the wheel not turn as it shows but as you did it for the RZ229. Thank you again, guys.
- alexstam78
If asoo can give resources for this watchface like previous maybe someone who knows to make bin file can do it. Believe me, if I had the knowledge to do it myself I would have done it, but no matter how many times I tried I did not succeed.
Sorry I do not want to port this watchface. I have already informed. Please do not do like this Have many reason I don't want to port GTR2 and face.io again. I've said it many times and I won't explain it again.
Let's just say if I find any interesting, I'll do it myself.
This watchface i will not do for sure please don't ask again. Any "WF maker GTR2 " can do Please help him .thanks
- alexstam78
I didn't ask you to do it, just if you could give thε resourses and someone else or Rcappa would do it. But since it is not possible, it does not matter, maybe someone wants to do it. Can you at least give resourses for G287? Thank you, asoo.
you request for resource is to make the whole watch.alexstam78 wrote: 11 Jan 2022, 11:40I didn't ask you to do it, just if you could give thε resourses and someone else or Rcappa would do it. But since it is not possible, it does not matter, maybe someone wants to do it. Can you at least give resourses for G287? Thank you, asoo.
G287 can unzip file all resource is already in that zip file, or you can repack GTR3 by use "Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3) " viewtopic.php?p=11692#p11692 after repack you can found all resource .
- alexstam78
- alexstam78
To say that you who have the knowledge obviously can not be done, thank you very much for the effort, to be well.asoo wrote: 10 Jan 2022, 00:41I think the technique of making it is the same as the previous one. I don't think it's too difficult for GTR2's "Watchface Maker".
Bye Good Luck
13-01-2022
- alexstam78
Asoo, can i ask something, to GTR3 this type of watchface can be done or not? If it possible, I'm thinking of going to GTR3, somewhere I saw that the seconds can move like in automatic clocks. Thank you again for support.
Yes , I think that it's can do on GTR3 Because GTR3 have a layer system more flexiblealexstam78 wrote: 17 Jan 2022, 11:37Asoo, can i ask something, to GTR3 this type of watchface can be done or not? If it possible, I'm thinking of going to GTR3, somewhere I saw that the seconds can move like in automatic clocks. Thank you again for support.
But I am not sure the circle can move like automatic clocks ( smooth seconds move ) or not , I did not test it
- alexstam78
They already upload Watchaface with that move here.
Thank you for info, I have in mind to go to GTR3 in the future for I can download your Watchafaces. I am fan of your works. https://amazfitwatchfaces.com/gtr/view/20957
Yes the seconds in hand clock it can do by use SashaCX75's scriptalexstam78 wrote: 17 Jan 2022, 13:20They already upload Watchaface with that move here. https://amazfitwatchfaces.com/gtr/view/20957
but seconds in circle like rz228 i am not sure because I never tested it.
And this script is not yet available in the standard editor. So I think I won't do it until. The standard editor will have it.
- alexstam78
Yes of course, i don't say put that move in the specific Watchaface but generally, in GTR2 can't be done by any means because of the limitation with animated graphics, but from what I understand this restriction does not exist in GTR3, at least as in GTR2.
