- Amministratore
G283 (GTR3) from asoo for GTR2
- alexstam78
- Has thanked: 173 times
Hello to community and to creators, can anyone port this Watchaface from asoo for GTR2, thank you very much. https://amazfitwatchfaces.com/gtr/view/19770
- Has thanked: 411 times
- Been thanked: 2050 times
My last job for the GTR2.alexstam78 ha scritto: 05 dic 2021, 05:26Hello to community and to creators, can anyone port this Watchaface from asoo for GTR2, thank you very much. https://amazfitwatchfaces.com/gtr/view/19770
From now on, I won't make a watchface for GTR2 anymore.
์Not test on real device , if have some issue or want to add or edit something please use program editor edit by yourself
- alexstam78
Thank you very much, assoo, much appreciate and thank you. Ok but don't have the skills for edit. Works ok I tested, only if you can add analog seconds at perimeter. Thank you again and this is my last request to you. THANK YOU AND HAVE MERRY CHRISTMAS.
Can not because the analog seconds has already been used to make circle's color.alexstam78 ha scritto: 08 dic 2021, 01:27Thank you very much, assoo, much appreciate and thank you. Ok but don't have the skills for edit. Works ok I tested, only if you can add analog seconds at perimeter. Thank you again and this is my last request to you. THANK YOU AND HAVE MERRY CHRISTMAS.
That all .
- alexstam78
I don't understand what you say. I mean the red dot at the perimeter of watchaface, like feru same Watchaface.
Can you see the perimeter is change the color ? That is a analgo's seconds hand. It used to make change the perimeter color , so can not add two "seconds hand" on the clock.alexstam78 ha scritto: 08 dic 2021, 08:39I don't understand what you say. I mean the red dot at the perimeter of watchaface, like feru same Watchaface.
OK I have some idea to make it but red dot maybe not stand out
if finish i will post in this link :
viewtopic.php?p=11340#p11340
and this is all.
- alexstam78
I don't have words, make it do as you think best, friend, thank you very much for all you done for me, merry christmas.
