Not showing up among fresh faces
thomastothuk
Hi all. So, I just uploaded two new watchfaces, but they don't appear when I click on fresh for my watch model. Do they have to be approved, or am I doing something wrong? Thanks.
- GIK-Team
- root
- Has thanked: 1164 times
- Been thanked: 279 times
Hi! Your watch face will become available in the catalog after the moderation. In case of incorrect filling of fields, it would be deleted. Just waitthomastothuk wrote: 04 Dec 2021, 10:42Hi all. So, I just uploaded two new watchfaces, but they don't appear when I click on fresh for my watch model. Do they have to be approved, or am I doing something wrong? Thanks.
How can I know what was wrong with my submitted watchface, if it doesn't appear and was deleted by moderators?
Thank you
Thank you
- Drongo
- Watchmen
- Has thanked: 34 times
- Been thanked: 12 times
You can write a private message to the moderator and find out what was wrong with your dial, but dials are always deleted only in accordance with the accepted rules on our website.RifoItaly wrote: 10 Dec 2021, 07:26How can I know what was wrong with my submitted watchface, if it doesn't appear and was deleted by moderators?
Thank you
And - https://amazfitwatchfaces.com/rulesUpload Rules
If you are an author, you may use our website as a platform to distribute your work.
If you are uploading someone’s modified watch face, you must specify the original author in the description.
It is not allowed to publish watch faces with personal images (personal photos, photos of family, friends, pets, children, etc.).
When uploading the watch face, you must fill all the fields. The name of the watch face must be unique (it is not allowed to repeat the names you already have).
You must specify as many tags as possible corresponding to the uploaded watch face.
The description box is required and must contain as detailed information as possible about the uploaded watch face (version description, style, color, theme, etc.).
The preview image should correspond to the watch face file and preferably be animated.
The watch face file must be compatible with the device for which this watch face is uploaded.
The watch faces with the images of a sexual nature, child pornography, unacceptable political and terrorist symbols, violence against people or animals, the propaganda of weapons or drugs, insults to the views of a particular religion are not allowed.
The use of the names of famous brands/companies in the name, tags or description of the watch faces is not allowed. The watch face that uses such name and/or is identical by the design to the one created by a famous brand/company can be removed from our website upon the request of the copyright holder, according to intellectual property law.
Failure to comply with any of the rules listed above may result in the permanent removal of the watch face you loaded without warning and the possibility of appeal to the administration.
The administration of the website makes decisions based on the general rules of the resource, as well as complaints received from website users.
Thank you for your answer.
I published 3 wf successfully so far.
Recently I tried to upload a fourth one and it was deleted (I tried more than one attempts, changing something every time).
I think guidelines and rules were ok.
Can it be the description only in Italian? (The wf is specifically designed for Italian leanguage only).
I think it is the sole difference among all my watchfaces...
- Drongo
- Watchmen
Try to publish the watch face again and we will solve this problem together.RifoItaly wrote: 10 Dec 2021, 09:53Thank you for your answer.
You can fill out the description of the watch face in the language that is convenient for you. And it is better to duplicate the description in English, so you can get more people interested in your work.
Ok.
I've just published the last version.
This time I included the description in English too.
It is called "A Parole", it is for GTR2(e) (my watch...)
Thank you again.
Thank you again.
...this time my wf has been successfully published.
I don't know what was wrong, at the previous attempts.
Thank you
Thank you
- Drongo
- Watchmen
The fact is that we perceived this work as defective. According to the preview, it was not entirely clear whether it was intended that way or the dial with bugs. When you added a description, everything became clear.RifoItaly wrote: 10 Dec 2021, 18:18...this time my wf has been successfully published.
Thank you
