GTS 2 mini custom watch face creation with AOD
Bloccato
CyclingAsia
Messaggio da CyclingAsia »
Hello all,
I've been implementing some watch faces using the dev.huami.com editor. I've got everything to work as expected, the editor is straight forward. I however have not been able to get an AOD watch face in my faces. I was wondering if there was anything extra that had to be done (configured) in the editor to allow exporting of the watchface with the AOD display?
thanks in advance.
nothing.tn
Messaggio da nothing.tn »
You can switch to tab Unlit Watch Face, click Copy Normal Watch Face. Then Export and try install again.
CyclingAsia
Thanks for the response. I tried that but the watch still doesn't give me the option to "follow current watch face". Oh well, I suppose my watch faces won't have AOD (not the end of the world)
Julien
Messaggio da Julien »
You should try again with latest updates, it does work.
daveliney
Messaggio da daveliney »
I have the same problem with the watchfaces I've created for the GTS 2 mini. Custom AOD setup in the web tool but not available on the watch. I've checked in the app and there are no updates available for the watch.
Shame I cannot ask Huami because I'm using the JavaScript trick to gain access to the tool.
mimidudu
Messaggio da mimidudu »
Hi, all
How do I do AOD?
Thamks
Bloccato
Torna a “Closed topics”
