How to remove watch faces (photos) from an iPhone app?
Patrick Mundo
Post by Patrick Mundo »
Can anyone tell me how to REMOVE a downloaded Stratos 2 watch face (or photo) from the app and watch (on an iPhone)? Thanks!
wvizmanos
Post by wvizmanos »
What I would do is factory reset the watch and uninstall/reinstall the app. Of course this is what everybody would probably do, until we hear from the others
emma281
Post by emma281 »
Force Touch again and select Customize to edit the complications and color of your clock face. To remove any unwanted clock faces, Force Touch the screen to enter editing mode, then swipe upward to reveal a trash can and the world Delete. Tap on the trash can to delete that clock face.
Charbs
Post by Charbs »
Hello emma281!
What do you mean by saying "to enter editing mode"? when I force touch the screen (so that I can swipe left or right to change the watch face) there is no ability to swipe upward. When I do, nothing happens (the image wiggles) are you talking about the built-in watch faces or the ones that the user installed later? Till now I couldn't find a way to remove or uninstall some of the watch faces that I don't want.
Peterdee
Post by Peterdee »
I got exactly the same problem.
It seems there is no way to remove the unwanted watch faces from the app.
Fandango68
Post by Fandango68 »
You can only do it via the PC and USB charger. Go to This PC\Amazfit Stratos\Internal storage\.watchfacethumb folder and delete the files there. Stupid really. Also, if you've downloaded the WFZ files via PC into the WatchFaces folder, they'll still be there, so make sure you also delete the ones you want to remove there as well. Very stupid way really Amazfit!
