How to install watchfaces (Haylou Solar)
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
Important information for Haylou Solar owners:
Watch faces are installed only on watches with firmware:
1836 Chinese (RH192HA)
1947 English (RH192IA)
Watch faces cannot be installed on firmware version 1160 yet!
The application you choose does not in any way affect the ability to install watch faces.
The ability to install watch faces is determined only by the firmware of the watch itself.
Watch faces are set in the official Haylou Fit app and the Hello Haylou app. Use up-to-date versions of applications.
Installation
Install one of the stock watch faces available in Haylou Fit
(if you have already installed one, you may skip this step).
Open the folder with the downloaded watch face in the file manager with the path:
Android/data/com.yc.hayloufit.
Go to any of these folders and find the .bin file. Copy the .bin file name.
Name example:
範例名稱.bin
Go to the custom watch face and rename it using the name of the standard watch face.
Copy the watch face file with the new name and transfer it to the folder from step 3 with a replacement.
Open the Haylou Fit app and open "Dials settings" go to "My dials"
Set the watch face
Or use a file manager that has access to the Android folder
In the Hello Haylou application, starting from version 1.11.0, third-party watch faces are installed by the standard capabilities of the application.
Video instruction
abrahamsitepu
Post by abrahamsitepu »
excuse me, how do i installed it using my iphone devices, since i couldn't find haylou folder on my iphone files, thank you hope u can help me
osmat
Admin
Post by osmat »
abrahamsitepu wrote: 22 May 2021, 11:51
unfortunately only android
haj_farbod
Post by haj_farbod »
Is it compatible with the new Haylou RS3 (LS04) watch? Or how to create a watchface for the RS3 watch? Thanks!
alperheper
Post by alperheper »
For a past time ago, a few months, it was working with your application, but now your app is not working. Also ads are really very much, i am hate from your new way. Egen with ads it is not working. Congrast with your useless managing!!!
Has thanked: 1140 times
Been thanked: 276 times
alperheper wrote: 17 Dec 2022, 21:10
Why did you write this here? If you have any problems, write it in the right thread and not just anywhere.
JayceeCook
Post by JayceeCook »
Doesnt work for me i never get the Chinese characters in the Android/data/com.yc.hayloufit.
Files folder. I think thing may have changed now that it uses the Haylou Fun app.
krizily
Post by krizily »
Qualche anima buona, in ITALIANO, potrebbe spiegarmi PASSO PER PASSO come installare i files.bin che ho scaricato quì sul mio AMAZFIT T REX che usa il MOTOROLA EDGE 20 PRO (ANDROID 11)???? Grazie in anticipo. K
McAND
Post by McAND »
Se usi notify for amazfit una volta Sincro li installi al volo
Users browsing this forum: No registered users and 13 guests
