How to make/edit watchfaces?
baxxcipo
Post by baxxcipo »
How we can make or edit watchfaces? would be very nice to know.
Lukass
Post by Lukass »
Unfortunately, there is as yet no such possibility
zsoltee69
Post by zsoltee69 »
Please editor
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
zsoltee69 wrote: 29 Apr 2018, 04:35
Please editor
We are working on it
zsoltee69
Post by zsoltee69 »
osmat wrote: 30 Apr 2018, 18:32
Please editor
THNX ;)
osmat
Admin
Post by osmat »
zsoltee69 wrote: 01 May 2018, 05:05
Please editor
THNX ;)
https://amazfitwatchfaces.com/editor/wa ... ditor/?cor
bui
Post by bui »
Does anyone have a detailed guide for creating watch-face? I do not understand how to insert the months and days of the week in letters.
:cry:
LostEchoes
Post by LostEchoes »
Guys are we supposed to run the Watchface.exe file on Windows ?
I download "AmazfitCorTools-1.0.0.1" and I unzip it to my desktop.
My goal is to edit a .bin file according to the instructions ("Disassemble .bin file with AmazfitBipTools (AmazfitCorTools for Cor), click on Select images and select them from watchface folder by Ctrl+A, then select JSON file by clicking on JSON Select. After that you can set numbers to display by clicking Settings or edit the watchface").
When I run the watchface.exe I get a screen for one second and then everything closes.
EDIT: Ok I found the way to extract the .bin contents, by dragging the .bin file on the .exe file.
Then I get into the watchface online editor, I choose / edit the settings I want.
The last step is to create the new .bin with the new edited files (images and .json file).
I still haven't found how to do this.
Alexam
Post by Alexam »
LostEchoes wrote: 08 May 2018, 06:42
I have the same problem :(
imn
Post by imn »
To create the new .bin file, dragging only the .json file on the .exe file. Is important have the images and the .json in the same folder.
After this step, you have the new .bin in the same folder of the images and the .json file.
Besides, you have a new .gif with the preview of the new design in the same folder.
You have more info in the first step of this guide:
https://forum.xda-developers.com/smartw ... s-t3746967
I hope it helps you.
