Hi to alls.
Howsolve the problem with issue smooth seconds , animation in firmware ( 3.22.15.7 )???
i see that Asoo and other upload a new version with fix.
I have last version of watch faces editor of Sasha.( 11.2)
but i have still problem with smooth second.
Thanks bros
issue smooth seconds[SOLVED]
- Has thanked: 438 times
- Been thanked: 2141 times
I recommend that you show the link of the dial you made and have the problemOmaradsl wrote: 04 Oct 2024, 15:57Hi to alls.
Thanks bros
so that those who want to help you can check it.
I test to unpack and repack your OAD42 watch face with version 11.2 and tested on my BALANCE , it can display smooth seconds correctly, so I am not sure why you having the problem as you mentioned.
Example of watch face repacked with 11.2
Omaradsl
- Has thanked: 16 times
- Been thanked: 8 times
sorry asoo, you're right, I wasn't very precise in describing the problem, and I thank you for your answer.
the problem noted is that the hand goes back one second in the cycle in which the dial is turned on. I attach the video to you.
https://drive.google.com/file/d/1Y347-g ... sp=sharing
see 3 seconds
and 8 seconds
the wathfaces is this:
https://amazfitwatchfaces.com/balance/view/1808
see 3 seconds
and 8 seconds
Omaradsl wrote: 05 Oct 2024, 08:53sorry asoo, you're right, I wasn't very precise in describing the problem, and I thank you for your answer.
see 3 seconds
and 8 seconds
From your example video, I think it works properly.
Smooth seconds may have some minor lag, like the video you showed.
This could be due to several reasons, such as:
- The watchface has a many animation, which may affect the smooth seconds.
- The image of the seconds face is too large.
- FPS setting.
However, the smooth seconds you showed as an example works properly.
If you want it to work more smoothly, you may try changing the FPS value to get the movement you want.
However, setting the FPS too high may affect the accuracy of the seconds slightly.
Example :
- changing FPS value
