Search found 3 matches
Return
by asoo
21 Sep 2023, 03:20
Jump to forum
Jump to topic
Re: Amazfit Balance Faces
1. The amazfit Balance has the same 480x480 screen size as the GTR3pro and uses zepp OS as the operating system.
So there is a possibility To be able to use Sasha's editor.
https://amazfitwatchfaces.com/forum/viewtopic.php?t=2743
you may try selecting the model as GTR3pro and create for your ...
by asoo
21 Sep 2023, 06:16
Jump to forum
Jump to topic
Thank you for the help. Hopefully I don't figure out a way to brick it lol
Or another option, you can use the official tool to create a watch face, but you have to prepare the image resources yourself. Because the official tool can't upload the finished watch face to make corrections
To use the ...
by Sharpshot90
25 Sep 2023, 14:49
Jump to forum
Jump to topic
I am on IOS device and the amazfit balance is populated on the list of devices im not sure if that makes a difference. Also, I did notice a bit of green on the watchface balance test, see the attached screenshot. not sure what to make of all this. for people having an issue connecting to the watch i ...
