La ricerca ha trovato 1 risultato
Return
da V.I.T.
21 lug 2020, 19:44
Jump to forum
Jump to topic
Re: Unable to install watchface to T-Rex from iPhone
You will have to go into the Amazfit app, then profile, then select the watch, then scroll down to the discoverable setting - make sure that is turned on. That was the issue I had to figure out.
Let me know if that helps.
