Hi.
I don't actually need a different watch face, but I would like the font on the activity timer to be bigger. Would a different/custom watch face have an effect on that screen, or would installing the Bold font be of any use?
Thanks.
Do custom watchfaces affect other screens?
I'm not certain if installing a bold font would help on the Activity screen,
but I do know that it affects the notification display and BIP menus (small text size).
If you're talking about the larger speed/distance/time displays, I don't think it will change them.
A custom watchface won't change any other screen.
As far as I know, the digit images in the watchface are used on the watchface only.
Regards,
Eric
Regards,
Eric
Ok, thanks Eric.
Might have to bite the bullet and experiment!
Cheers.
Cheers.
