iPhone Verge Lite installation?
br9900
Post by br9900 »
Hi.
I'm reading these instructions for iOS phones but thinking your phone needs to be jail broken in order to do this?
Installing the Watch faces via AmazTools (iOS):
Open the file and select the [Browse] tab at the bottom.
Select my Iphone in the [browse] tab and find the Amazfit folder
Find the watchSkin folder in the Amazfit folder. If there are files in it, delete them all first.
Open Amazfit, select a dial to synchronize, and then enter the watchSkin folder after synchronization, A new folder will appear. This is the dial file you just synchronized. When you enter this folder, there will be a dial file (*. bin) and a picture of the dial, and copy the name of the file. Delete this dial file later.
Copy the dial files you want to replace into the watchSkin folder, rename the copied dial files to the name of the official dial files you just copied, and, The dial picture doesn't care about it.
Return to Amazfit and synchronize the dial that was synchronized just now
Or use AmazTools:
Has thanked: 1184 times
Been thanked: 281 times
br9900 wrote: 17 Sep 2019, 23:19
Hi.
No, this can be done without a jailbreak.
br9900
Post by br9900 »
Thanks for the reply. How do you browse the folder from an iPhone though?
br9900 wrote: 18 Sep 2019, 13:24
https://support.apple.com/en-us/HT206481
br9900
Post by br9900 »
Thank you! I didn't know that feature existed LOL.
So I did a sync of a stock dial from the AmazFit app. I then used the Files app to view the /amazfit/watchskin folder. For some reason, the amazfit folder does not exist or gets created. I've tried this several times now.
Let me know if you have any suggestions. :idea: Thanks.
br9900
Post by br9900 »
UPDATE:
Hi GIK-Team. I got it working. It was a user error. Thank you for the great app and website!
iDjAndre
Post by iDjAndre »
br9900 wrote: 26 Sep 2019, 02:23
UPDATE:
How did you see the Amazfit folder? I have the same problem
