Page 1 of 9
Posted: 09 Sep 2019, 07:17
by lumenvindex
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
Re: WF_Builder (watchfaces for Mi Band 4)
Posted: 09 Sep 2019, 12:44
by Dandow
That's awesome!
Thanks a lot, i'll test it today.
I was wondering, did you contemplated "gif"?
Posted: 09 Sep 2019, 13:14
by lumenvindex
Dandow wrote: 09 Sep 2019, 12:44
That's awesome!
Not sure what you mean by that. You would like to see a feature of saving animated GIF from preview? But Mi Band 4 WF Tool already make gif file every time you pack a watchface.
Posted: 09 Sep 2019, 14:18
by lazimk
Great! I will try this. I found this on 4PDA.
It was in Russian. So i was about to request to translate that into English.
Thanks for sharing this here
Posted: 09 Sep 2019, 16:41
by Dandow
lumenvindex wrote: 09 Sep 2019, 13:14
That's awesome!
Like this pip boy
https://amazfitwatchfaces.com/mi-band-4/view/5300
Posted: 09 Sep 2019, 18:16
by lumenvindex
Dandow wrote: 09 Sep 2019, 16:41
Like this pip boy
Still don't understand you. At all. Give me some more detailed explanation.
Posted: 10 Sep 2019, 08:50
by Dandow
lumenvindex wrote: 09 Sep 2019, 18:16
When you open the json you se that pipboy has a sequence of images, its not static.
I couldn't try it yesterday but i'm gonnna play a bit today 🤭
Posted: 10 Sep 2019, 09:04
by lumenvindex
Dandow wrote: 10 Sep 2019, 08:50
You're asking whether program can or cannot add Animation block to config? Sure it can! I even made my own variant of Pip-boy watchface with this program.
Posted: 10 Sep 2019, 21:19
by Menpanda
Hello, I would like to learn how to make my own animated mi band 4 watch faces, is there any tutorial to use this tool? I tried to convert a gif int a APNG but it didn't work. Could someone please help me?
Posted: 11 Sep 2019, 02:50
by lumenvindex
Menpanda wrote: 10 Sep 2019, 21:19
There are no tutorials about this program as far as I know. To add animation you need to split your gif file into a set of png frames (I used "ezgif" service for that). Then open needed watchface in WF_Builder, turn on the Animation block and choose all png files of the set. Than you should change X and Y parameters to place the animation on the watchface.
Unfortunately there is no easy way to adjust animation speed - the Speed parameter should be larger than 4 (otherwise the animation won't play on the device with the latest firmware), but large values cause animation blinking. Probably you'll have to adjust the speed by changing the amount of frames.
Don't forget to cut off all unnessesary pixels from the frames and use Palette mode to pack a watchface. Your bin file shouldn't exceed 320 Kb size to be successfully uploaded to Mi Band.
Posted: 11 Sep 2019, 19:31
by Dandow
Is it not possible to put months as letters instead of numbers? I mean, I try writting in the json to count 12 images instead of 10, but seems to reestart at the 10th
Posted: 12 Sep 2019, 02:30
by lumenvindex
Dandow wrote: 11 Sep 2019, 19:31
Mi Band uses these images as digits only. Therefore it recieves only 10 images.
But you can unpack some watchface with "months as letters" and see how it could be done. Watch out, don't twist your mind. :D
Posted: 13 Sep 2019, 08:00
by sachann
it is possible. I have my watchface modified to have months as text instead of nubers.
I only use the short form of the month but full month is also possible with all 12 names.
have a look at my thread: viewtopic.php?f=62&t=828&p=2477#p2477
Posted: 13 Sep 2019, 08:18
by Miro
You achieve that with the latest firmware ?
Is the MIBand4 App still work to add custom WF in Mi Fit ?
I can't get my watchfaces to work anymore ..
Posted: 13 Sep 2019, 08:21
by Navajoa
great Tool, but there is one problem. I opened .json, Add status "Do Not Disturbe", and PNG. When I create the new .json and will create an new .bin with Mi Band WF Tool V4 I get some errors.
When I edit the existing original .joson with hand, I can create the .bin without problems.
Kind Regards,
Navajoa
Posted: 13 Sep 2019, 08:39
by lumenvindex
Navajoa wrote: 13 Sep 2019, 08:21
Could you provide me with your json so I could see what's the problem? When editing json by hand, you still can pack it using WF Tool 1.4.0?
Posted: 14 Sep 2019, 17:00
by lumenvindex
Uploaded new version of WF_Builder (0.9.6) to fix a bug reported by Navajoa. Some other optimizations were also made.
Posted: 20 Sep 2019, 08:30
by ypiripillo
there's a virus in WF_Builder0.9.6.zip
detected by standard Windows 10 antivirus and confirmed by virustotal
Posted: 20 Sep 2019, 10:39
by lumenvindex
ypiripillo wrote: 20 Sep 2019, 08:30
There is a "Virus?" spoiler in the first post. Thanks for your attentiveness. VirusTotal score is 11 of 62, by the way. :evil:
Of course it's up to you whether you use this program or not. I can even send you my sources, if you need it.
Posted: 22 Sep 2019, 08:58
by user839
Where is the download link?
Posted: 22 Sep 2019, 09:41
by GIK-Team
user839 wrote: 22 Sep 2019, 08:58
Soon, in the first message. We have technical problems that we will solve shortly.
Posted: 22 Sep 2019, 11:48
by lumenvindex
Lots of changes in new WF_Builder 0.9.7. Get it from the link in the first post.
Posted: 25 Sep 2019, 16:18
by phamaral
Any tips for making watchfaces with gifs? I had to get rid of LOTS of frames to make is fit in the 320kb limit, tried compressing the PNGs but it makes no difference. Now I have 10 frames, and they play way too fast. Anything I can try to fix this?
Posted: 25 Sep 2019, 17:52
by lumenvindex
The larger animation frames weight the slower animation is. Palette packing makes smaller frames. I'm afraid there is no silver bullet for making long calm animations in a watchface. At least for now. Just try to find some balance between size and speed.
Posted: 26 Sep 2019, 16:38
by mysiak
lumenvindex wrote: 22 Sep 2019, 11:48
Thanks for the update. I see only LIB subfolder, without actual WF_Builder0.9.7.exe executable in the archive. Did I miss something? :)
