Página 1 de 1
Amazfit GTR 42mm
Publicado: 04 Sep 2019, 23:13
por Niiccoo27
Hello, Where did I find watch faces for amazfit GTR 42mm? In the catalog there are only watch faces for 47mm.
Re: Amazfit GTR 42mm
Publicado: 14 Sep 2019, 16:27
por Fmcg
Agreed. There are only two watch faces available for the GTR. Would be nice if all GTR faces were compatible with either size.
Publicado: 17 Sep 2019, 06:44
por tombraider
now 4 available for 42 gtr, but i never managed to change watch face successfully@@
Publicado: 18 Oct 2019, 14:57
por stationz
Zero watch faces for 42mm to me.
Publicado: 18 Oct 2019, 19:06
por Niiccoo27
It really has none for the 42mm in the catalog.
Do you know if the ones for 47mm are compatible with 42mm?
Realmente não tem nenhuma para o 42mm no catalogo.
vocês sabem se as para o 47mm são compatíveis com o 42mm?
Publicado: 23 Oct 2019, 17:22
por MF1970
I also tried to install the 4 new watch faces that are newly available but i cannot manage to install them!!! Help please
Publicado: 31 Oct 2019, 07:07
por oggeman
I want to create my own watchface to GTR 42mm. But I don't know how to extract any existing .bin file to get into the image files.
I have downloaded and installed the latest Python 3.8. I also have the watchfacetool for Amazfit BIP .bin files that I have previously used for BIP watchfaces but this does not seem to work in the same way with GTR .bin files.
Can anyone please give any tips? I would really appreciate it. Thanks.
Publicado: 27 Dic 2019, 11:12
por kampanita
There is a simple method for converting 47mm to 42mm ->
Take the 47mm.bin file and compress it to zip format.
Go to
https://wakeup.aliennation.lv/amazfit/index.php and select/upload that zip file....wait and then push the button for downloading transformed zip file.
Uncompress that zip returned by the web and there you can see a _42_packed.bin file for your GTR-42mm
So easy, so if you like a 47mm wf you only need to transform it in this way and you'll get your 42 version
Publicado: 21 Feb 2020, 14:44
por An7
Everytime I try that site, it returns me an error on the page. Tried A LOT of different bins/zips.
Publicado: 26 Feb 2020, 15:29
por Veseli
Hi, I bought a gtr 42mm. Now, I have 3 watch faces in the watch. But I can change only two of them, the third one is always the same.. do you know something about it?!
And can I some how have the possibility to change all the 3 of them?!
Thanks for the answers!!
Antonio
Publicado: 20 Abr 2020, 10:47
por Landuh
An7 escribió: 21 Feb 2020, 14:44
Same here, always returns me an error on the page. I Tried some different bins/zips.
