Getting actual miles to disply.
jcwill
How are developers getting actual miles walked to register on the Bip. I see that some have achieved this - how is this done? Also, are there a repository of coding syntax for the editor? Seems like developers are using items not in their image resource. Thanks/
- Has thanked: 404 times
- Been thanked: 2022 times
๋Just put "SuffixMilesImageIndex": xxx in the "Distance "
xxx = Image name "Miles"
Ex.
And pack the .json to .Bin with AmazTool All 0.1.0.11 ( viewtopic.php?f=29&t=782 )
Ex.
"Distance": {
"Number": {
"TopLeftX": 37,
"TopLeftY": 39,
"BottomRightX": 88,
"BottomRightY": 49,
"Alignment": "TopCenter",
"Spacing": 2,
"ImageIndex": 21,
"ImagesCount": 10
"SuffixImageIndex": 41, <-------- image KM --------
"DecimalPointImageIndex": 42,
"SuffixMilesImageIndex": 299 <--------- image MI ------------ put this command line for switch betwen KM to MI by use MiFit
jcwill
What do you mean xxx = Image name "Miles". What does your 299 represent?
299 is name of picture ( 0299.png )jcwill wrote: 19 Aug 2019, 20:25What do you mean xxx = Image name "Miles". What does your 299 represent?
Ex.
0299.png is
you can change xxx to name of your picture
**** name of picture in BIN is a number ( 0000.png to 9999.png )
jcwill
I finally got the miles to display ... thank you. But for some reason after I make the ,bin it puts the wrong background in. when I'm editing it it's fine ... it's after I pack it is when it's doing it.
