Page 1 of 7
py amazfit tool
Posted: 17 Aug 2019, 20:13
by afwafwafw
what is...
what isn't...
requirements
  • python3(tested on 3.7.4)
  • pillow(tested on 6.1.0)
## usage
* for verge lite
  * see scripts folder
    * to unpack
    * to pack
      * to pack
      * to unpack
* for GTR
  * to unpack
  * to pack
      * to pack
      * to unpack
Re: .bin pack/unpacker for verge lite
Posted: 19 Aug 2019, 02:02
by TXK
Can you make EXE programs?
Posted: 19 Aug 2019, 03:41
by afwafwafw
Sure but not right now.
You can generate it by executing auto-py-to-exe, though.
Posted: 19 Aug 2019, 16:26
by fx_advanc
cool bro,
i have using it today, straight forward. but no animation.
Posted: 20 Aug 2019, 05:30
by afwafwafw
Yes, you're right.
It's a little trick but you can get animation .gif after unpacking packed_bin again.
i.e
python main.py WATCH_FACE.json # now you've got WATCH_FACE_packed.bin
python main.py WATCH_FACE_packed.bin # in WATCH_FACE_packed/ folder you can see gif file in there
Posted: 22 Aug 2019, 04:13
by 侯侯大神
Why can't you use your tools to unpack your bin, only unpack the official ones
Posted: 22 Aug 2019, 08:41
by fx_advanc
I need to get the live editor, easier to locate the dial .png files to X & Y coordinate.
Do you have any guide tool for numbering x 1-360 x y 1-360 grid
AFWAFWAFW
Posted: 22 Aug 2019, 09:27
by afwafwafw
侯侯大神 wrote: 22 Aug 2019, 04:13
I always use mine to pack/unpack my .bin.
Have you tried latest version of my tool?
Which bin cause issue for you? Can you give me a link for it?
Posted: 22 Aug 2019, 09:28
by afwafwafw
fx_advanc wrote: 22 Aug 2019, 08:41
AFWAFWAFW
Hi. I'm using GIMP as a guide tool. :)
Posted: 22 Aug 2019, 11:02
by 侯侯大神
Thanks for replying, friend, I should not be using the latest version
Posted: 22 Aug 2019, 17:45
by manelto
Is It possible have this tool for GTR amazfit?
Posted: 22 Aug 2019, 21:54
by afwafwafw
manelto wrote: 22 Aug 2019, 17:45
As I don't have a GTR watch, I cannot make the tool for GTR easily. There's one person who forked mine. He've changed the name as amazfit_gtr_tools so you can wait for his work or Amazfit watchfaces tool(posting.php?mode=quote&f=26&p=2400).
Posted: 22 Aug 2019, 21:56
by afwafwafw
侯侯大神 wrote: 22 Aug 2019, 11:02
No problem. If you have any issue, let me have .bin for debugging.
Posted: 23 Aug 2019, 06:15
by manelto
afwafwafw wrote: 22 Aug 2019, 21:54
OK! Thank you.
The problem seems to be the resolution (360 vs 454) and the header (header.bin). But maybe there is something else (sure: D).
Posted: 24 Aug 2019, 13:29
by manelto
viewtopic.php?f=29&t=782&p=2423#p2423
Posted: 24 Aug 2019, 14:53
by fx_advanc
Does gimp shows the coordinate? what name of the features.
Posted: 24 Aug 2019, 14:57
by afwafwafw
fx_advanc wrote: 24 Aug 2019, 14:53
https://docs.gimp.org/2.10/en/gimp-conc ... uides.html
Right?
Posted: 25 Aug 2019, 04:27
by fx_advanc
Can you help me position the dial, thanks [mention]afwafwafw[/mention]
here's the link " https://justbeamit.com/89pag
Posted: 25 Aug 2019, 04:38
by fx_advanc
Posted: 25 Aug 2019, 10:23
by afwafwafw
here's corrected version for tick.zip
https://drive.google.com/open?id=1xT_ct ... ou1v-q5cXv
Just remember that let "CenterImage.X", "CenterImage.Y" equal to pin position of time hands.
By comparing it with original tick.json, you can see how to set position of hands.
Posted: 26 Aug 2019, 06:45
by fx_advanc
yep been trying, i tried to set EMC first,
tick.json i forgot where did i put the original file (i take it from verge).
Posted: 26 Aug 2019, 13:23
by afwafwafw
TXK wrote: 19 Aug 2019, 02:02
https://github.com/ghtalpo/amazfit_verg ... ease/win32
see usage/for_windows_users section in readme.md
Posted: 26 Aug 2019, 13:49
by Ferodo
afwafwafw wrote: 26 Aug 2019, 13:23
Thank you so much :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
Re: py amazfit tool
Posted: 24 Sep 2019, 08:04
by koolgao
buenos dias compañeros para cuando https://github.com/ghtalpo/amazfit_verg ... ease / win32 este podra empacar las esferas de 42 mm del gtr? para el gtr de 47 va de lujo pero para el de 42 no hace nada
Re: py amazfit tool
Posted: 24 Sep 2019, 09:21
by glenan
Hello
Is there any tuto how to use Amazfit GTR TOols 32b ?
Thanks.
