Pagina 1 di 1
Mi Band 4 faces Not appearing in Mi fit's local displays.
Inviato: 04 lug 2019, 10:09
da Stupidiputs
Yesterday I downloaded nearly 20 mi band faces and only 4 worked for me. The other ones doesnt appear in local faces in mi fit app. Im android user. Anyone has any info about it, maybe is it incompability with global version? Noone of the animated faces works for example.
Re: Mi Band 4 faces Not appearing in Mi fit's local displays.
Inviato: 04 lug 2019, 10:13
da lukbe
Here is manual how to load watch face
viewtopic.php?f=14&t=709
Is your procedure same?
Inviato: 04 lug 2019, 10:27
da Stupidiputs
lukbe ha scritto: 04 lug 2019, 10:13
Ive copied all faces and png this way: (i cant post a video link faak xdd, search in youtube "cara install custom watch face mi band 4" its in hindi I thinl but its the only video Ive found)
In summary, I created new folder for each band face in the "watch_skin_local" and copied in there the face and png/gif file.
Inviato: 04 lug 2019, 11:41
da osmat
Stupidiputs ha scritto: 04 lug 2019, 10:27
Animated can not be installed from the local folder. Try to do a substitution
Inviato: 04 lug 2019, 12:22
da Stupidiputs
Finally It works by making a substitution, but its a headache xdd
Inviato: 04 lug 2019, 13:45
da osmat
we are working on the application give us time
Inviato: 04 lug 2019, 19:24
da Kpochmx
osmat ha scritto: 04 lug 2019, 13:45
Thank you, we are waiting for Quality watchfaces with really good animations.
Inviato: 14 lug 2019, 13:19
da romstemp
If you are unable to use Hex program, you can try this program to patch bytes 17 to 24 in one click
Small program for patch file.bin on bytes 17 to 24 edit FF FF FF FF FF FF FF FF to 24 00 d0 03 00 00 3d 78 ( for PC )
