Deleted "Standard" watch face
Bloccato
herronm
Messaggio da herronm »
Hi, I'm new here. Somehow, I deleted on the watch faces that comes with the Bip (the one with the light gray background - and my favorite). How do I locate it and re-install it?
Thanks,
Max
daydreaming
Messaggio da daydreaming »
if you've deleted the watchfaces on the watch, just wait for a upgrade or use the settings-factory reset on bip and reconnect it..
if you've deleted the ones on your phone , delete all the application data of mifit then restart the app
mine is chinese which may be different from yours .any furthermore questions just reply :)
slimfictiv
Messaggio da slimfictiv »
question: how do you delete watchfaces from the watch? I would gladly delete most of them if I knew how. The ones in Mifit you can only delete the ones stored in the Local Tab, or replace one on the Online Tab with something else.
daydreaming
ha! in fact that's not a easy thing. maybe some unofficial firmware can do it. Or you can try to edit the firmware yourself.
however, you don't have to delete it in normal use.because it usually cause the watch out of work .
Bloccato
Torna a “Closed topics”
