Is there any way for me to upload the watch face directly
Posted: 20 May 2026, 12:41
Is there any way for me to upload the watch face directly to my watch instead of using the website to scan a QR code? sorry is this is a dumb question.
Community
https://amazfitwatchfaces.com/forum/
viewtopic.php?p=17161#p17161Postmortem wrote: 20 May 2026, 12:41Is there any way for me to upload the watch face directly to my watch instead of using the website to scan a QR code? sorry is this is a dumb question.
I haven't tried it lately but I used to do this:Postmortem wrote: 20 May 2026, 12:41Is there any way for me to upload the watch face directly to my watch instead of using the website to scan a QR code? sorry is this is a dumb question.
Thank you!taw_bip wrote: 20 May 2026, 20:43I haven't tried it lately but I used to do this:Postmortem wrote: 20 May 2026, 12:41Is there any way for me to upload the watch face directly to my watch instead of using the website to scan a QR code? sorry is this is a dumb question.
I install watchfaces from my Android phone this way:
1. download the .zip file to your phone. On Android, it goes into the Downloads folder.
2. clear the data/cache storage from the Zepp app.
3. load the Notify for Amazfit app (you need to set it up, get your watch's pairing code, etc. follow the instructions)
4. when all set up, click on the "Devices" icon at the bottom. Tap "Watchfaces" press the "hamburger" settings icon on the top-left. Select "Custom watch-face (.bin)"
5. This will open up the phone file manager. Select the Downloads folder. Then select the .zip file. Hit the "Install" button.
6. If all goes right, it will install the watchface.
7. Once you're done testing, do the storage app/cache wipe of the Notify for Amazfit app.
8. Open the Zepp app and re-login to connect it to the watch.
But the method asoo has put together makes it very easier to install from a Windows machine. But this method uses a QR code.
viewtopic.php?p=22231#p22231
