Página 1 de 1
Damaged watchfaces t-rex 3
Publicado: 02 Dic 2025, 03:27
por Xysad
Hi. I'm trying to download watchface HGT 43 by author Jaconix, but Zepp app says error: send package to device failed. When I try to edit WF through the app, it shows me 4 errors in the path.
Can anyone fix this face?
Re: Damaged watchfaces t-rex 3
Publicado: 02 Dic 2025, 04:13
por asoo
Xysad escribió: 02 Dic 2025, 03:27
The issue is that when you sync a watch face to your watch, the Zepp app reports a "send failed" message because the developer has used unsupported character in name of file , such as those in languages other than English. If these character are present, syncing may cause problems.
- Untitled-2.png (43.27 KiB) Visto 1397 veces
I've fixed the issue. Try downloading it and testing it.
I tried syncing and was able to install it.
QR-code for sync :
- QRCode_HGT-43Fix.png (19.73 KiB) Visto 1397 veces
If you want the edited zip file, download it here.
PS. As for "When you try to edit WF through the app, it shows me 4 errors in the path.", I can't answer that because I'm not sure about the editor you're talking about.
Publicado: 02 Dic 2025, 04:26
por Xysad
Thank you very much
