Page 1 of 1
TSWF04 Garmin on T-Rex 3
Posted: 24 Nov 2025, 17:26
by Ricardo.cz
Could you please make this watch face on trex3? Thank you
Re: TSWF04 Garmin on T-Rex 3
Posted: 25 Nov 2025, 11:00
by asoo
Ricardo.cz wrote: 24 Nov 2025, 17:26
This watchface has some widget that are different from the original.
Image.Image
Top image progress is Humidity.
TSWF04_Trex3.zip
(231.49 KiB) Downloaded 101 times
Top image progress is sunrise , sunset
TSWF04_Trex3_S.zip
(231.49 KiB) Downloaded 135 times
QR Code :
viewtopic.php?p=21699#p21699
Posted: 25 Nov 2025, 13:21
by MarioLie
Here is your dream look.
Posted: 25 Nov 2025, 14:37
by Ricardo.cz
thank you very much great work. all your versions are great 👍😉
Posted: 02 Dec 2025, 11:32
by danielmartis
Ahoj , prosím ťa urobil by si ho na T Rex 2 alebo Gtr3?
Posted: 11 Dec 2025, 17:08
by danielmartis
Ďakujem 👍
Posted: 02 Feb 2026, 13:13
by Angel@
Hola es posible hacer el QR de la esfera
Posted: 02 Feb 2026, 14:42
by asoo
Angel@ wrote: 02 Feb 2026, 13:13
You simply download the file you need,
then upload it to this website using your ID, and you can install it via the QR code that the website generates for you.
https://amazfitwatchfaces.com/upload
Or try this QR code.
QR Code
TSWF04TREX3:
TSWF04TREX3_S:
The file in this QR code is located at https://catbox.moe/. In some countries, it may not be accessible, or the website may be unavailable at certain times. Therefore, if you cannot install it, you will need to upload it yourself as previously instructed.
Posted: 02 Feb 2026, 15:31
by Angel@
thank you so much asoo
