How to hide weather Icon
Moderatori: asoo, Watchmens
xpdev
Messaggio da xpdev »
Hi
I created a watch face with SashaCX75's software for Amazfit with ZeppOS, specifically for Balance.
I'd like to hide the weather, the icon, and the city using a button on the watch display...
I can't seem to create the JSscript code to hide the weather icon. I don't know what to write in the function, and I can't get to the weather icon, which I can do perfectly well with the watch hands.
Can anyone help me?
Has thanked: 411 times
Been thanked: 2050 times
Messaggio da asoo »
xpdev ha scritto: 01 ott 2025, 11:25
Hi
Can anyone help me?
If you would like to hide a widget, you can use
.setProperty(hmUI.prop.VISIBLE, false); to hide the widget.
For example, if you want to hide (Weather icon , temp high , temp low , temp curent , City name)
Codice: Seleziona tutto
normal_weather_image_progress_img_level.setProperty(hmUI.prop.VISIBLE, false);
normal_temperature_high_text_img.setProperty(hmUI.prop.VISIBLE, false);
normal_temperature_low_text_img.setProperty(hmUI.prop.VISIBLE, false);
normal_temperature_current_text_img.setProperty(hmUI.prop.VISIBLE, false);
normal_city_name_text.setProperty(hmUI.prop.VISIBLE, false);
On the other way, if you want to show ( Weather icon , temp high , temp low , temp curent , City name )
normal_weather_image_progress_img_level.setProperty(hmUI.prop.VISIBLE, true);
normal_temperature_high_text_img.setProperty(hmUI.prop.VISIBLE, true);
normal_temperature_low_text_img.setProperty(hmUI.prop.VISIBLE, true);
normal_temperature_current_text_img.setProperty(hmUI.prop.VISIBLE, true);
normal_city_name_text.setProperty(hmUI.prop.VISIBLE, true);
You can place this script directly in a button to call it.
Or, you can define it as a function to call it through the button.
I hope this helps you.
PS: If you create a project and encounter a problem, we recommend attaching the project. This will make it easier to investigate the issue.
xpdev
Thanks for your help, I'll do my tests.
This isn't working.
On my watch face, the current temperature is displayed using characters and not an image. I don't know if that's the cause.
Can you help me further?
Project:
Allegati
AIO_Simply_16.zip
(194.43 KiB) Scaricato 49 volte
Messaggio da asoo »
if you use ttf or system font to display temp.
you can try this script :
normal_temperature_current_text_font.setProperty(hmUI.prop.VISIBLE, false);
You can actually find the name of the widget you want to take action with in the index.js file, inside your ".zip" file.
Example of editing :
AIO_Simply_16.zip
(193.67 KiB) Scaricato 52 volte
xpdev
Thank you, works fine
xpdev
Sorry, I still need your help.
Why doesn't this code entered directly into a button work?
let showmeteo = true;
function toggleMeteo() {
    showmeteo = !showmeteo;
    show_hide_meteo(showmeteo);
function show_hide_meteo(vis) {
    const visibleValue = vis ? 1 : 0;
    normal_weather_image_progress_img_level.setProperty(hmUI.prop.VISIBLE, visibleValue);
    normal_city_name_text.setProperty(hmUI.prop.VISIBLE, visibleValue);
    normal_temperature_current_text_font.setProperty(hmUI.prop.VISIBLE, visibleValue);
Messaggio da asoo »
xpdev ha scritto: 03 ott 2025, 07:01
The script you created is in function form, so
when you place it inside a button, nothing happens. Since no functions are being called, you should put all the function scripts in the Scirpt section in the (User-defined...) section. ( user_function.js )
user_functions.js
Then, you can enable the functions via a button, just adding the functions you want to work.
toggleMeteo()
show_hide_meteo()
Button
Immagine[/url]
I tested your function and it didn't seem quite right. I fixed it as follows:
let visibleValue = '';
if ( vis == 1 ) { visibleValue = true }
if ( vis == 0 ) { visibleValue = false}
Or this
function show_hide_meteo() {
    let visibleValue = showmeteo;
Or this
Button add only
toggleMeteo()
I've attached a sample project. You can open it and test it with an editor.
This file isn't a watchface, it's just a project file.
AIO_Simply_16.rar
(404.45 KiB) Scaricato 51 volte
Preview for Tested
I recommend understanding the structure before proceeding.
Otherwise, you might get confused.
xpdev
Ok, now it works, thank you
xpdev
@asoo
Sorry mate
Two questions:
1) How can I test the .rar files you're sending me? They can't be tested with SashaCX75's software for Amazfit with ZeppOS.
What can I use directly on PC instead of compiling WF and uploading it to Watch to see if it works?
2) I can't hide the digital seconds.
In my watchface design, they're built directly from text, not images.
Thanks again and sorry for the constant inconvenience I cause you.
Messaggio da asoo »
xpdev ha scritto: 15 ott 2025, 08:04
@asoo
Sorry mate
Two questions:
The .rar file contains the project used with Sasha's editor. You can simply uncompress it with WinRAR and bring it to use with sasha's editor . I don't understand why you can't use it.
As for hiding the digital seconds, if you want to hide them, just look in the index.js file and see what the digital seconds widget is, and then use
.setProperty(hmUI.prop.VISIBLE, false); to disable the display.
Here, if you're using a font, it's called normal_time_second_text_font.
To disable the display, use
normal_time_second_text_font.setProperty(hmUI.prop.VISIBLE, false);.
I think I've already explained it.
As for testing watchfaces, you can use a simulator without syncing to the watch.
However, simulators sometime work not correctly simulate the functionality. Therefore, if you use a simulator such as ZeppPlayer or an official simulator, sometimes the simulation may not be accurate, or some scripts may not run. ZeppPlayer, in particular, can only simulate about 90% of the time, as ZeppPlayer can only support ZeppOS1. https://mmk.pw/zepp_player/
If you want a high-quality simulator, you need to use an official simulator.
https://docs.huami.com/docs/1.0/guides/ ... tor/setup/
However, installation is more complicated.
I won't go into details about the simulator itself, as it requires you to understand the steps yourself before you can use it. So, for the use and installation of the simulator, I will not explain anything.
You can find more information at the links I've attached, as well as some on this website.
xpdev
Thank you so much mate
xpdev
I'm embarrassed to ask you for help again.
I managed to do everything you suggested.
Two problems remain.
1 - Hiding the date from .js file
2 - Changing the background directly from the .js file
I'm attaching the project with the changes.
Can you help me again?
Allegati
Super Simply Face - AIO.zip
(198.1 KiB) Scaricato 50 volte
Messaggio da asoo »
xpdev ha scritto: 16 ott 2025, 09:10
Change Background: I don't understand what you're trying to do here. The editor already has a widget available, and I see you've already used it. From what I've seen, I haven't found any errors.
Regarding the date, I don't understand why you can't fix it. I've already explained how.
Just find the name of the date widget in index.js and disable it
in this case name is "normal_day_month_year_font" , So you can following script: "normal_day_month_year_font.setProperty(hmUI.prop.VISIBLE, visibleValue);" for hidden it. This is no different than hiding the seconds, as I explained earlier.
If the next time it is the same problem , I won't respond.
Next time, if you have any questions about creating a Balance watch face, I recommend posting in the forums:
Balance : Watchfaces discussion
viewforum.php?f=178
or
Balance : Watchfaces creation (order table)
viewforum.php?f=179
It should be area for the problem you are asking about.
Please see the example and understand.
I've changed the function call from the button (because from what you provided, it probably wouldn't work properly).
I've added a button to hide the date by clicking on the Dateline.
Example
Super-Simply-Face---AIO.zip
(196.57 KiB) Scaricato 55 volte
Note : If the next time it is the same problem , I won't respond.
xpdev
Thank you
Torna a “Zepp OS”
