Color
marrud12
Color
Post by marrud12 »
WhenI download a ZIP of a model here and open it, in "assets" are all files *.png. When I open one e.g. with IrfanView or Gimp, first it says, "it's a TGA, not a PNG", then opens but all colors are completely wrong, blue instead of red etc.
Do you know a prgram that shows the right colors or can convert it correctly?
Been thanked: 2122 times
marrud12 wrote: 06 Aug 2025, 13:49
I think you mean the PNG for devices running ZeppOS. Those PNG images are encoded in ZeppOS format. If you want to edit them, you'll need to convert them to regular PNG format first.
There are two ways to do this:
1. Use an image converter (ImageToZeppOS) by SashaCX75
viewtopic.php?p=19042#p19042
2. Unpack the watch face file using the program
"Watch face editor for Amazfit watch on ZeppOS" by SashaCX75
Once you unpack, the editor will convert the PNG file to a standard PNG format.
Once you're done editing, you need to convert those PNGs to ZeppOS format before adding them to the watch face pack.
marrud12
Post by marrud12 »
Thanks very much! Works fine.
