Page 1 of 1
SashaCX75 V.12.2: mile per km
Posted: 04 Feb 2025, 11:07
by Emiliomc
Hi guys.
I hope I am heading to the appropriate subforum. If not, I apologize. I have a problem with a watchface I created for my Amazfit GTS 4. I am using the SashaCX75 app version 12.2. I have created an element that is distance. But it does not match the data that my smartwatch provides me. It is a smaller amount. I think it is in miles, when I want that data to be in km. For the creation of the element I do it using "Value by source", not "Numeric values". I have looked at application settings, but I cannot modify that. Also in the "index" file, in the "watchface" folder to try to edit it. But it doesn't seem to be possible either. I have searched the forum, but I have not found anything or I have not known how to search properly.
Is there a way to have the distance information not in miles, but in km?
Thank you.
Re: SashaCX75 V.12.2: mile per km
Posted: 04 Feb 2025, 11:45
by asoo
Emiliomc wrote: 04 Feb 2025, 11:07
Hi guys.
Thank you.
If I understand your question correctly, I think the units displayed on the watchface are based on the settings in the Zepp App.
It is not defined in the watchface's script.
In the script, it only defines which characters to display the numbers.
And ,If zepp is setting unit KM, which image will be used to display the units, and if it is MI, which image will be used to display the units.
If you set it to KM in app zepp, the watchface will display the distance as KM. Conversely, if you set it to Mi on the watchfce, the distance will be displayed as Mi.
Setting unit on App Zepp
Posted: 04 Feb 2025, 12:14
by Emiliomc
Thank you very much for responding. In the Zepp app settings it is in Km, not Mile. I don't know why in the watchface that I created the distance traveled is less than what my smartwatch actually tells me. Once the created watchface was installed, I restarted it. But it still shows me a distance less than the real one. I think the distance shown on the created watchface is in miles.
Posted: 04 Feb 2025, 12:51
by asoo
I'm not sure why you're having this problem.
I don't have a GTS4 so I can't test it properly.
I suggest you try sending the watchface you're having problems with, maybe someone with a GTS4 can help you test it.
Posted: 04 Feb 2025, 19:22
by taw_bip
I had an issue with a watchface that showed kilometers in the display rather than my preferred miles. I reached out to the watchface maker and he had to write code to make it work. I'll see if I can dig it out.
Posted: 05 Feb 2025, 09:30
by Emiliomc
It's a good idea. I give you the .zip file of the sphere. It's strange, because in the Zepp app settings it is in km, not miles. The data I have both in the application and on my GTS 4 is correct. Steps, pulse and calories match. But in the watchface I created it doesn't match. I have discovered that the result it gives me is not in miles. It is simply less than in km. For example, the distance is actually 0.81 km. But it shows, in this example, 0.77 km. I don't know if anyone can help me with this.
Plus E4.zip
(3.3 MiB) Downloaded 86 times
Posted: 05 Feb 2025, 11:51
by asoo
I tried installing your watch face on Balance and checked the distance display, the data in system and on watchface are exactly the same. I am not sure why on GTS4 it has the problem as you mentioned.
Posted: 05 Feb 2025, 14:09
by Emiliomc
The truth is that I don't understand it. I have the Zepp app updated. I have cleared app cache. The firmware of my GTS 4 is updated. I have restarted it several times. And the watchface data created in relation to distance does not correspond to reality in km. The watchface data is not mile either, because it does not match mile. It is simply not correct. I attach photographs.
Posted: 06 Feb 2025, 19:43
by SashaCX75
It seems to be a specific feature of this model. You can try to use ‘Numeric values’ image set instead of font. It might help.
Posted: 07 Feb 2025, 13:56
by Emiliomc
Thank you. I'll try it that way. But I don't understand why it would cause problems only with the distance data and not with the rest of the data.
Posted: 07 Feb 2025, 18:12
by SashaCX75
The TEXT_FONT widget is used to display data in font. This widget is not documented anywhere, so its normal operation is not guaranteed.
Posted: 08 Feb 2025, 10:22
by Emiliomc
Fixed with "Numeric Values". This way it does show the correct distance information in km.
